4L60E Transmision with carb
Old 10-26-2009, 03:45 PM
demonseed304's Avatar
Car: GMC 1500 P/U 4x4
Axle/Gears: 4:10
Will a 4L60E work with a carberuator When i have a Shot Tbi Unit
Old 10-26-2009, 09:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 4L60E Transmision with carb
I wouldn't think so. The 4L60e is electronically controlled with it's own PCM - I would assume this PCM needs input from the car's ECM in order to know shift points and etc. If swapping to carb, there will no longer be ECM input from o2 sensor, coolant temp, distributor (swapping to carb can't use the cc dizzy anymore), etc.
There may be some kind of seperate PCM controller on the market that could get info from it's own sensors, but last time I saw one of these it was about $1200 JUST for the aftermarket PCM. Be much cheaper to get another TBI unit or rebuild the one you have.
Old 10-26-2009, 09:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Yes and no. We have a fleet of newer trucks all converted over to propane that still run an electronic transmission. The ECM doesn't control fuel to the engine at all. They use what's called a Superfix for alternate fuels to correct for any fault codes but you won't need that.
Because the ECM won't be controlling the injectors, most of the emission stuff can be removed but the ECM needs to stay to control the transmission. The only conversion you need to do is to modify a TPS sensor to tell the ECM what position the throttle is at so that it knows how to shift the transmission.
80's GM pickup trucks with TBI have a perfect TPS. It has a lever on it that can be controlled by a carb. You can either modify a bracket to have an arm on the carb directly move the lever on the TPS or remotely mount the TPS and use a cable/rod connected to an arm on the carb to do the same thing. It still needs to be calibrated with a scan tool. Idle is around 0.50v and WOT is around 4.50v.
Old 10-26-2009, 10:28 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
"The only conversion you need to do is to modify a TPS sensor to tell the ECM what position the throttle is at so that it knows how to shift the transmission."
Just what I was going to post. Yes you need to intall a TPS sensor.
Old 10-27-2009, 06:15 AM
Axle/Gears: 4:10
and what type of modification will that be. and how much will it cost. please send a diagram or instructions
Old 10-27-2009, 08:17 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Old 10-27-2009, 08:30 AM
Axle/Gears: 4:10
thanks I was befudeled
Old 10-27-2009, 08:32 AM
Axle/Gears: 4:10
is that choke side or throtle side
Old 10-27-2009, 04:03 PM
one92rs's Avatar
Car: SOLD!!!!!
tci and several trans companies offer stand alone controllers for using the electronic transmissions in cars with carbs.
Old 10-27-2009, 07:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
It doesn't matter which side of the carb you mount it on. The majority of those style TPS rotate counterclockwise when looking at the arm. You can see in the top picture that the pivot of the carb arm is at the bottom and the pivot of the TPS is at the top. It's using a rod to pull the TPS and the TPS has an internal spring to help return to idle. The TPS is also adjustable so at an idle, the proper voltage can be obtained. These lever style TPS use a different plug than what's on a third gen TBI TPS but it can be easily adapted.
The ECM uses a 5 volt reference signal. It sends 5v to the sensor then sees how much voltage comes back. At an idle, GM TPS are around 0.50 volts and WOT is around 4.50 volts.
Old 10-29-2009, 08:08 AM
Axle/Gears: 4:10
thank you thats all i needed
Old 11-28-2015, 08:11 AM
aaronr's Avatar
I got a 93 sonoma\ s10 original 4.3 4l60e recently swapped small block Chevy into it got it running and driving but still trying to get tranny to work correctly it's carb small block Chevy with MSD so I've got the original VSS working I've got the original distributor wire ran to the tach wire from MSD box bus still trying to figure out if original temperature gauge has to be hooked up and exactly how to do that I have the intake sensor hooked up but still is reading maxed out because I don't have the sensor hooked up in the head and if it has to be hooked up which wires go to the sensor on the head I have two wires by my intake a black and green wire with a to pin plug that aren't hooked up are those it I have aftermarket gauges also still trying to figure out throttle position sensor I have one plugged in and set at idle but not mounted to carb but it still takes off in second gear I have second and third not sure about overdrive haven't been over 40 also have reverse no first I know
2012sergen11
10-13-2015 07:38 PM
efiguy
09-27-2015 01:30 PM
Damon
09-26-2015 04:29 PM
lanceflame44
09-25-2015 12:28 PM
Quick Reply: 4L60E Transmision with carb
