92 rs camaro 5 speed and drivetrain for sale!
Old 10-23-2009, 08:37 PM
ChevyRS-305's Avatar
Car: 1989 Camaro RS/ 1992 Camaro z28
Engine: 383 Stroker/ ls3 e-rod
Transmission: borge warner t-56/ tremech t-56
Axle/Gears: 10 bolt, 3.55/ dayna 44(viper) 3.07
i have a used t-5 transmission w/ driveshaft and stock rear open 10 bolt diff for sale. i nerver driven the car but the previouse owner said reverse gear would grind when first enguaged and that i know for myself the rear end yoke to center section gaset is bad and leaking grease. i know this from when i towed the car and above the yoke is sprayed grease all under the car from centrifical force. i have bagged and tagged all bolts and retainers( all but the bellhousing bolts. the axel in still on the car to push it around but the trans and driveshaft is sitting in my garage off to the side.
Old 10-26-2009, 05:06 PM
Project84TA's Avatar
Car: 85 Camaro IROC, 88 K-1500
Engine: 357 TPI, 350TBI
Transmission: T-5, NV3500
Axle/Gears: 3.42 posi, 3.73 i believe
Re: 92 rs camaro 5 speed and drivetrain for sale!
how much are you looking to get for the trans? and any idea if its a wc or nwc trans?
Old 10-27-2009, 09:32 PM
i have no idea if it is a wc or nwc but im looking for around $500
Vintageracer
01-10-2020 05:33 PM
colton_carlson
03-08-2019 12:21 PM
InfinityShade
08-22-2015 08:00 PM
kyleb24
08-15-2015 08:24 AM
89lsc
08-14-2015 04:58 PM
Quick Reply: 92 rs camaro 5 speed and drivetrain for sale!
