How to tell if Posi?
Old 10-10-2009, 11:57 AM
Josh91's Avatar
Im looking to get a posi disc brake rearend but the rearend is already out of the donor car. How do you guarantee its a posi without putting it back in and smokin the tires?
Old 10-10-2009, 12:04 PM
big gear head's Avatar
Re: How to tell if Posi?
Remove the cover and look inside. This is the ONLY way to be sure. Believe me, I have used the other quick methods before and lost money because they are not reliable. Spinning the axles might work sometimes, but other times it will cost you.
Old 10-10-2009, 01:35 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Take the cover off before paying for a LIMITED SLIP rear. It should look like this.
Old 10-10-2009, 02:14 PM
Josh91's Avatar
Do you have a picture of what I should be looking for in a posi?
Old 10-10-2009, 02:29 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
More info in the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old 10-10-2009, 02:33 PM
http://rides.webshots.com/album/55410292AnMJrE
Take a look at these. The Auburn and Governor Lock were the only limited slip (posi) differentials used in the third gen Camaros and Firebirds. Someone could have installed something else over the years, so be sure to check it out.
Old 10-10-2009, 05:53 PM
blackroc68's Avatar
Not the only! How about the 9bolt borg warner!
Old 10-10-2009, 06:18 PM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Stay away from the gov lock and avoid the 2 series posi's.
Old 10-10-2009, 06:32 PM
DJP87Z28's Avatar
What do you think that above picture is???????
Old 10-10-2009, 08:21 PM
OK, the Auburn and Gov Lock were the only ones available in the 10 bolt. The 9 bolt had the Borg Warner limited slip, which is a cone type, like the Auburn. The point that I was trying to make was that the Eaton Posi was not used in the thrid gen. The Eaton Posi is available now in 26 and 28 spline versions. It's my opinion that the Eaton Posi is the best street/strip limited slip differential for high performance GM cars.
Old 10-10-2009, 11:09 PM
Josh91's Avatar
Thanks for the help so far. But what is the difference between the Auburn and the Gov lock? And which is preferred?
Old 10-11-2009, 08:47 AM
Neither one is prefered. The Gov Lock is fragile and the Auburn will wear out, is not rebuildable, and will fill the rear end with powdered metal. The Eaton Posi is prefered. The Gov Lock is kind of rare. They usually break the gear oon the governor and then they just spin one wheel. Most had the Auburn. The problem is that you can't tell how close the Auburn is from being worn out. It might work fine for a few months and then stop working. When it wears out it will still drive the car, but will only spin one wheel.
The best thing to do is install a new Eaton in a rear end that has the gear ratio that you want. If you are just wanting a bolt in rear end that you don't have to do anything to then just pick one with the Auburn or Gov Lock and hope for the best. They held up pretty well for many people while these cars were new.
Old 10-11-2009, 12:40 PM
Josh91's Avatar
Thanks for the info.
Old 08-01-2013, 04:57 PM
CoolDansta's Avatar
So what would be better a rearend from a third gen or a 4th gen
Old 08-01-2013, 05:49 PM
I answered that in your thread.
KO1
16
10-15-2015 05:00 PM
92projectcamaro
09-29-2015 07:07 PM
Quick Reply: How to tell if Posi?
