Horrible high pitched grinding noise when I turned my key to start the car
Old 10-02-2009, 01:14 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
The topic title says it all.. It's the first time the car has done this, and it scared the hell out of me.. It's wet out today, and I was in my girlfriends driveway when it did it.. It was very loud, and sounded like it came from the starter.. Any chance my starter is going? It didn't make the sound again when I got home.. Help!
Old 10-02-2009, 01:33 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Horrible high pitched grinding noise when I turned my key to start the car
might be dry bushings in the starter,starting around
1988 some of the starters have needle roller bearings
instead of bushings.
Old 10-02-2009, 01:50 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
could be the teeth on either the starter or the flywheel/flex plate are worn out, allowing the gears to not mesh correctly and slip. This happened on my buddys bronco, replaced the starter, and all was well.
Old 10-02-2009, 06:20 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Did the starter manage to crank the engine when it made the noise?
Old 10-02-2009, 07:31 PM
Kevman's Avatar
Engine: 2004 LQ4
I'm not sure, It scared the hell out of me from how loud it was.. But I turned it off, and tried again and it was fine..
Old 10-03-2009, 08:56 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Yep, exact same thing that happened to my buddys bronco. He would turn the key and if the teeth didn't grab well enough he would get that noise, if they did grab it would start.
It will only get worse until you cant start the car.
I say replace the starter.
Old 10-03-2009, 11:06 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Yeah, get under and check the starter/flexplate. The nose of the starter could be cracked. Or you could possibly be missing teeth on the flexplate ring gear.
hokis
08-09-2015 03:57 PM
Kaweh
08-09-2015 02:54 PM
86Base
08-08-2015 01:34 PM
92projectcamaro
08-06-2015 01:20 PM
Quick Reply: Horrible high pitched grinding noise when I turned my key to start the car
