Stubborn O2 Sensor
Old 10-02-2009, 12:27 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Stubborn O2 Sensor
Hi guys,
Ok, my o2 sensor has f*ing locktight on it or something because I've been trying for two days and it won't budge. I've had it constantly soaked in penetrating oil, heated it with a torch and have let the car run for a few minutes. And I'm using a 24" cheater bar. And it still won't come off!!!! Any tips???
TIA
BTW, it's my maro
Old 10-02-2009, 03:01 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Stubborn O2 Sensor
Originally Posted by novafirebirdguy
Hi guys,
TIA
BTW, it's my maro
More heat... You need to get the bung just about glowing if it's a stubborn one.
Old 10-03-2009, 11:32 AM
Will do, thanks!
Old 10-03-2009, 01:48 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Do you have access to an impact gun? They work wonder on things that are stuck and are less likely to break things than using a pry bar.
Old 10-03-2009, 01:52 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Dont be bashfull, get under the car and remove the down pipes, if you havent done it. Then do the 1/2 inch deep socket with an impact wrench as the other member has said. That would be the best thing to do unless you hit the junkyard and salvage another header.
Old 10-03-2009, 01:53 PM
Nope, don't even have a torch. Have to borrow my friends. If I can't get it out I might just buy some headers. I can't get a decent seal where my manifolds meet the y-pipe so I need em anyway.
Old 10-03-2009, 03:46 PM
Is it your passengerside where there is a bad seal? If so, is there like a donut piece in between the header and down pipe? This is used to mount the header and downpipe so that there is a seal. the donut looking thing is flared so that it can fit inside the flared end of the down pipe.
Old 10-03-2009, 11:09 PM
It leaks both sides, has the "donut" on both too. They have absolutely no reason to leak. Everything is on right, bolts are tight. Even took unhooked em and slobbered clear silicone every where. Only helped for a little while. They're just so damn rusty they'll never seal. I'll get headers eventually. Hopefully I'll get better mpg too, I'm getting comparable too or less than my formy, NOT cool. I've still got another 1k to dump into this POS
Old 10-03-2009, 11:17 PM
[quote= I've still got another 1k to dump into this POS[/quote]
I like your style bro. Calling your own car a POS. Cool bro. Peace.
Old 10-04-2009, 11:50 AM
Let the truth be known, it's rolling sh*t, but it's my rolling sh*t and it's the second best car in my school parking lot, (some one has an l98 iroc). If I'm not poor this summer I might get it painted. If I ever fix everything
Thanks guys
Old 10-04-2009, 06:22 PM
Novafirebirdguy, good luck to ya. Youve got a positive attitude towards the second best POS car in the school parking lot.Keep on rollin bro! Peace.
Old 10-04-2009, 09:06 PM
Thanks man, soon it'll be the best POS on the lot. I guess that's an accomplishment Good luck with your
Italian
Retard
Out
Cruising
Just kidding, IROC's kick ***
Old 10-06-2009, 04:22 PM
No problem. and thank you .
Old 11-14-2009, 09:52 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
Thats probably why you need to replace your O2 sensor
Old 11-15-2009, 12:27 AM
Yes, the car will run rich because some (ok alot) of the exhaust isn't getting to the o2 sensor. But I really need to replace it cause I broke the wire off it. I just bought some headers and have to use a different o2 sensor anyway, so I'm not even bothering with it.
Jonboy2312
04-27-2010 07:48 PM
TheWraith
04-24-2006 01:39 PM
orangetang
06-03-2005 06:39 PM
chekbaka
11-27-2004 10:13 PM
Quick Reply: Stubborn O2 Sensor
