Timing Tab
Old 09-24-2009, 08:51 AM
zcam96's Avatar
Car: 1989 irocz lb9 57k miles
Transmission: manual
Timing Tab
I need to reinstall the distributer in my 89 iroc LB9. I set number on cylinder on tdc and the haynes book says to rotate the moter till the balancer mark lines up with 0 degrees, then set the distributer in with the rotor pointing between number one and eight plug wires. The problem I am having is the timing tab has no numbers on it, even after srubbing the grim off. Does anyone know where o degrees is on the tab? Please help!!!
Old 09-24-2009, 10:10 AM
On Probation
Atilla the Fun's Avatar
Car: seeking '90.5-'92 'bird hardtop
Engine: several
Transmission: none
Axle/Gears: none
Re: Timing Tab
Look for the biggest of the "sawteeth" It's towards the driver's side. That'll be zero.
Old 09-24-2009, 10:18 AM
zcam96's Avatar
Re: Timing Tab
Thanks....hopefully I'll get this thing runnin tonite!!
Old 09-24-2009, 10:40 AM
grumpyvette's Avatar
Re: Timing Tab
I read this several times and either your not clear on what your saying or your confused as to what your doing
finding TDC
http://forum.grumpysperformance.com/...php?f=70&t=967
step one, pull the #1 plug and place the tip of your finger over the plug hole and rotate the engine until you feel COMPRESSION build as the number one cylinder, piston starts its compression stroke as the mark on the damper gets close to the timing tab, then remove your finger and continue turning the engine until the timing line on the damper aligns with the timing tab (0) TDC
once thats done the engine should not rotate any more until the distributor is seated correctly.
once thats lined up you drop the distributor into the engine so the rotor on the distributor points at the #1 cylinder when it seats and you install and lightly tighten the clamp and connect the wires, connect the timing light and set the timing at about 6-8 degrees BTDC at idle as a start point., if the distributor won,t fully seat the oil pump drive shaft needs to be turned a few degrees with a long large flat blade screw driver and re-try seating it while, it might take several tries until it lines up, it will seat into the distributor base gear once the oil pump drive aligns with the oil pump slot in the distributor gear base
midge54
12-27-2019 04:14 PM
The_Phoenix
02-04-2016 07:10 AM
masonta
08-31-2015 10:14 PM
91REDZ28VERT
08-18-2015 10:16 PM
kitt23
Exterior Parts Wanted
08-15-2015 12:37 PM
Quick Reply: Timing Tab
