'91 Camaro RS engine will not start
Old 09-17-2009, 06:36 AM
graemej's Avatar
Car: '91 Camaro RS
Hi all, little bit of a forewarning I am new to this whole fixing up cars bit so bare with me. Anyhow, my camaro seems to have a mind of it's own when it comes to starting, somedays it will run fine all day no problems at all. Other days it will just go completely dead and not do a thing when I try to start it. I have replaced the alternator and battery, also replaced the battery posts. Now it is sitting out front of my house refusing to start, won't make a sound except for a little click when I try to start it. Wondering if anyone might know what the problem may be?
Old 09-17-2009, 02:26 PM
NINÅ's Avatar
Car: LOWERED ♦ CRIMSON METALFLAKE
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
WIRE MIRE
Remove and clean all wires going to the starter & solenoid.
Then coat the area with marine protectant.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old 09-22-2009, 10:59 AM
TwoBrakeTony's Avatar
Car: 1990 Camaro RS
Engine: SBC 350 w/ Holley 780cfm DP
Transmission: 700R4 w/ 2800rpm stall
Axle/Gears: Borg Warner 9 bolt 3.70 posi
Re: '91 Camaro RS engine will not start
Did you fix it yet? I have a solution....
Old 09-22-2009, 11:30 AM
acian21's Avatar
ignition control module
distributor wired wrong
ignition switch
ecu
starter
starter silonoid
i replaced all that ause mine had the same problem but its just a trial and error thing
Frozer!!!
01-19-2024 04:55 PM
Spyder_TheGamer
12-25-2015 05:07 PM
bradleydeanuhl
08-12-2015 11:48 AM
92projectcamaro
08-06-2015 01:20 PM
Quick Reply: '91 Camaro RS engine will not start
