305 cylinder heads, what's best?
Old 09-15-2009, 10:50 PM
25th92RS's Avatar
Car: 1992 RS, 2000 Z28
Engine: LO3 with TPI Swap, LS1
Transmission: 700-R4, 4L60E
Axle/Gears: 3.42 with TruTrac LSD
Trying to plan a build up of an LB9. What cylinder heads are best to go with. Been contemplating vortecs but am concerned with the extra expense of the vortec compatible intake manifolds. Are vortecs best? Are there equally flowing alternatives for cheaper or equal priced?
Is the LB9 even worth the effort, should I hold out for a L98 and build that up?
I'm looking to keep the TPI setup as well, no conversion to mini ram, or stealth ram.
Old 09-15-2009, 11:03 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: 305 cylinder heads, what's best?
The Vortecs are good for the money. You can get a set for $860.00 complete. Trick flow Super 23 aluminum heads are right around $300 +/- more, depending on which max. lift version you go with, which isn't a bad price for aluminum heads. There aren't many heads with the 1.94 intake valves, which is what you'll need for your 305. I'm going to build my 305, too. I think it is worth it because you can always swap the parts onto a 350 later, if you want to go that route. You can make near 400 fwhp with a n/a 305, which is plenty to make a third gen scoot quite nicely, especially when you use the right gears and get your tranny working properly. Your 3.42 gears should be perfect for the built 305. You have a tru trac lsd....nice! I like those.
Old 09-15-2009, 11:15 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I found this thread fun and interesting https://www.thirdgen.org/forums/tpi/...tpi-310-a.html
Old 09-16-2009, 08:10 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
For your 305 I would say go with a set of 601s or 113s, the vortecs are nice heads but the intake will cost and additional @$400. The 113s ( 58cc aluminum) are nice heads weighing in @50lbs less than the 081s or 601s and flow good with some port work. The 601s(53cc Iron) can be made to flow well (read sittingbulls thread @ porting 601s) and give you a bit more compression. Also there the cheapest youll find ..... 113s= $300-$650+ depending whats done..........601s= $50-$200+..... vortecs=$75-$400+. I have a set of each of the heads listed above and Im probally going with the 113s
Old 09-16-2009, 08:18 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
!!!!! Where did you find them for that price? I want a set!
Old 09-16-2009, 08:24 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
He meant $300 more than the $865 vortecs so $1165+/-
Old 09-16-2009, 08:48 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Oh, right.
Old 09-16-2009, 06:24 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Ha ha ha....I wish they were that cheap. I'd have them already.
Old 09-16-2009, 06:26 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I'm curious about the 113 heads now. What the frick are those?
Old 09-16-2009, 08:56 PM
Fast355's Avatar
Car: 1983 G20 Chevy
The L98 aluminum heads found on the TPI Corvettes. A better version of the same head is being made for the ZZ4 and marketed through GMPP. It has factory port work and upgraded springs.
Old 09-16-2009, 10:39 PM
25th92RS's Avatar
That's an awesome thread you found. I could only dream that I make that kind of HP out of a 305. Easily possible but obviously the right conditions have to exist and it looks like Fast355 really found the right combination of things. Great build!
Old 09-21-2009, 09:16 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I ran corvette 113s on my 305 for a long time. car ran mid 13s with 3.23 gears, no traction and stock tune. 113s are the BEST heads for a 305 IMO
Old 09-21-2009, 10:56 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
To which thread were you referring?
Old 09-22-2009, 09:01 PM
Fast355's Avatar
Car: 1983 G20 Chevy
I dunno though, I really like the 059 Vortec 305 heads too. They work VERY well too.
Old 09-22-2009, 09:13 PM
25th92RS's Avatar
Fast355 - Have you every used or heard much about EQ CH305A heads? I guess they're Vortec in design but even cheaper.
Or what about the World Products Torquer 305's?? Just curious.
Old 09-23-2009, 04:22 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I'm sure they do. I've never dealt with them, so wasn't making any claims.
Old 09-30-2009, 10:34 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
From all that I have read about modding the 305, the Vortec heads are the most popular choice because they make good power and are half the cost of aluminum heads. I mean, 372 horsepower is 372 horsepower, whether it's from a Vortec headed engine or an aluminum headed engine. I'm going with the Vortecs on my 305. And you can make well over 400 hp with the Vortecs on a 350, if you ever decide to go that route.
Old 09-30-2009, 11:26 PM
25th92RS's Avatar
I'm probably not going to go with aluminum heads because of the expense but if I find rediculous deal I'll obviously jump on it. But if you can save 40 or 50 pounds of weight and still get 372hp then I'd say I'd have to favor the Aluminum heads..... technically speaking.
Old 10-01-2009, 01:08 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
True. I guess the trick flow heads would be the best bet for Aluminum heads. They're fairly cheap, for aluminums, and they're more designed for the 305 than any other ones I've seen. I personally am not worried about the weight of the heads. I can't see it making too much of a difference for a daily driven Camaro.
Old 10-01-2009, 09:47 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
you can get 113 casting vette heads for less than $500
Old 10-06-2009, 01:09 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Torquers are nice for the price. Went for a ride in a 305 with Torquer heads and ZZ4 cam. GREAT midrange.....lit the tires at will.
Hawk92Z-TDZ would know more about the car as he did the tune.
Old 10-13-2009, 06:09 PM
killa66cam's Avatar
Did you do any port work to the heads?
Cam
Old 10-14-2009, 11:49 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I found a guy in Florida who does the 059 305 specific Vortec heads for $320 bucks each. That's not too shabby, in my book. And 059's make good power. I am torn between these and aluminum trick flows. grrr...I don't know if the extra $500 for the 10:1 compression is worth it.
Old 10-15-2009, 12:34 PM
killa66cam's Avatar
I found some 059's for $200...used of course. I think that the 059's are a good used head that you can usually get a pretty good price on. I would guess that the TF 175's are great heads, may well be the best heads for a 305, but for a $1000 more...they just aren't worth it to me! Especially not on a 305 that I am probably going to replace at some point with a 350, 355, 383, 400, etc. If you want aluminum heads, you may want to look for the vette 113's. There are some on ebay right now for about $400 shipped. That is still $800 less than the TF 175's. If you are never planning to get rid of the 305, and you have the money, go ahead and get the TF 175's. If there may be some other plans that you have in mind...I would probably lean towards cheaper alternatives. Just my 2-cents...not worth much, I know, but I have been thinking about heads for my 305 for a lil while now.
Cam
Old 10-15-2009, 12:35 PM
slow305rs's Avatar
TFS head will add .2 to your compression ratio due to the slightly smaller than stock combustion chamber.
I'd say worth the extra money. Lighter head, produce more power out of the box and the WOW factor.
Old 10-16-2009, 11:27 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
The trick flows should bump the CR up higher than that, I would think. For a poor dude like me, the Vortecs are the best for my money.
Old 10-17-2009, 06:46 AM
Car: 89 IROC
Don't forget to add the cost of a vortec base manifold (if you don't have one). The vortec heads wont fit right with the regular bases.
Old 10-17-2009, 10:52 AM
killa66cam's Avatar
I got a set of 059 Vortec heads, a Professional Products Vortec intake, and a GM HEI distributor for $325 last night. I am probably going to end up getting a Edelbrock Vortec intake. They range in price from about $200-$250 new...probably half of that if you can find them used.
I'm with New2Chevy on this one. For my broke a$$...I went with the 059's.
Cam
Old 10-17-2009, 11:26 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
You also have to figure the cost of doing a valve job, changing the springs, etc., to allow for higher lift cams. The 059's I found in Florida are $320.00 each with all the work done to them already. That's much cheaper than if you got them done at a machine shop. The valve job alone costs at least $200.00, and that's a cheap estimate.
Old 10-17-2009, 11:27 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Most guys will want to ditch the tpi and get another intake anyway, to take full advantage of the new camshaft. The Vortecs are still a cheaper way to go.
Cam
Old 09-01-2017, 11:20 PM
Shockwe9's Avatar
Car: 1992 Rs/Z28 camaro
Engine: 6.0 LS
Where would you personally buy the vortec heads from ?
Old 09-01-2017, 11:29 PM
Shockwe9's Avatar
Engine: 6.0 LS
Jake_92RS
01-28-2020 10:37 PM
NinjaNife
08-23-2015 11:49 AM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
Quick Reply: 305 cylinder heads, what's best?
