TH400 crossmember
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
TH400 crossmember
Has anyone made a crossmember for the th400 to fit in a camaro? I would like to fab one myself if I could get some measurements and ideas from someone I have heard that I can use the torqe arm thats for 700r but I have not tryed I am waiting to save enough money to get 400 built before I pull the old 700r out.
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Re: TH400 crossmember
Google GM transmissions and youll find several pages comparing the overall dimensions of each GM trans
Build your crossmember accordingly
B&M and Hurst sell a bracket to bolt your stock TA bushing to the crossmember under the tranny mount. If you are capable of fabricating a crossmember you can handle this bracket as well
Off topic, why are you having a TH400 built up for your 305 TPI? I highly doubt youll break a stock TH350 even with a heavily modded 383
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks Pocket I didnt think about that. The reason for 400 is I already have one but needs rebuilding and this is the 3rd 700r put behind this 305.I dont know why but they all went bad and that is the main reason I got this car so cheap. Also will be replacing 305 with a L31 hoping to get above 400 hp.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Just thought I would add this,I looked up dimensions for th400 got 3 different measurements off the only 3 pages I looked at, then went to my shop all 3 were wrong for my short tail 400. lol guess thats hot rodding.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
kammi10
11-09-2015 08:28 PM
darwinprice
17
10-11-2015 11:51 PM
tmork454
09-29-2015 06:33 PM
1986, 86, 90, 91, body, camaro, cross, crossmember, dimension, fabrication, gm, member, th400, trans, transmission
