LM7 plus FAST intake
Old 09-04-2009, 10:19 PM
last_'s Avatar
Car: 91 Camaro RS
Axle/Gears: stock...
Okay, so I have already saved money for the LM7 that will go in my 91 Camaro RS. Not being experienced I was curious if the ..
FAST LSXr 102mm LS7 intake would bolt to the LM7 and what restrictions that would put on cylinder heads. link:
http://www.compperformancegroupstore...Code=LSXR102mm
I had the same question for the regular 92mm version:
http://www.compperformancegroupstore...y_Code=LSX92mm
Also!! While the LM7 will be a major friggen upgrade from the factory L03 that currently resides I will need to build the LM7 for low end torque. It has recently been brought to my attention that the LM7 is a little lacking in low end torque.
Also!! ..again.. I will be putting a mild bore/stroke combo into engine.
Thanks in advance.
Old 09-05-2009, 07:23 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: LM7 plus FAST intake
i think you should go with the smaller one. and unless you are going to do some headwork,big cam, and a real good flowing exhaust i think either will hurt you. the lm7 does not flow like the ls1 series engines.
Old 09-05-2009, 09:19 AM
last_'s Avatar
Car: 91 Camaro RS
cool, thanks for the reply. as for flow numbers i have been bouncing around between air flow research, trick flow and racing head service. so the super cool intake would have some super cool (and well flowing) cylinder heads to go along with it.
Old 09-05-2009, 05:16 PM
On Probation
Atilla the Fun's Avatar
Car: seeking '90.5-'92 'bird hardtop
Engine: several
Transmission: none
Axle/Gears: none
My Lm7 totally kills the 2 LO3s I had. Any stock LM7 will give you over 290 ft-lbs at just 1500 rpm, and builds to over 325 by 4000. Compare that to the LO3 making peak torque of 255 ft-lbs at 2400 rpm, it's no contest. The LM7 is only lacking when compared to larger engines. The FAST 102 is only for LS3/L92 heads, it won't work on any heads that you can bolt onto a stock-bore LM7. The 92 will work for you, but you can probably find a used FAST 90 for half the money. Even with cam and heads, an LM7 won't miss those last 2 mm. The wisest thing to do for better flowing heads is a pair of CNC-ported 5.3 heads from Total Engine Airflow. They offer several stages, but stage 1.5 is the most flow for the least dough, stage 2 is past the point of diminishing returns.
Old 09-06-2009, 06:43 PM
last_'s Avatar
Car: 91 Camaro RS
once again thanks! you seem to have already built to where i want my car to be!
Old 09-07-2009, 12:03 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Stck with the LS6 intake and F-body throttle body. It will breathe plenty for a stock-ish 5.3L.
Old 09-07-2009, 12:44 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
That's true, but used FAST 90/90s are selling for the same $ as a new LS6 intake.
Old 09-08-2009, 09:57 AM
last_'s Avatar
Car: 91 Camaro RS
and i would venture to gues that the fast intake is better already than the ls6 intake?
so not that i will get there per say but what is th emax power that the fast 90 90 will support? just curios!
Old 09-09-2009, 09:43 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I can't give you an exact number, but I know 570 HP without boost or nitrous, maybe more on a wilder build. A used LS6 intake would be best for your stock heads, but why buy it when it can't keep up with better-flowing heads, such as TEA-ported heads?
Old 09-09-2009, 11:50 AM
last_'s Avatar
Car: 91 Camaro RS
my goal is for 500 foot lbs at the rears. not a big fan of keeping the stock cylinder heads. that is why i have been lookin at companies like RHS and AFR.
I have not ever heard of TEA until now. Ill hafta check em out.
Old 09-11-2009, 05:37 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
To get 500 ft-lbs at the rear tires, you will have to go with an old-school big block, or a power adder like nitrous or turbocharging. Keep in mind that a T56 and a 12-bolt will still eat 13% of what the emngine makes, assuming you use good synthetic lubricants in the trans and axle.
Why spend $2400 on a new pair of heads, as good as the AFRs are, when you can get the same results for $1000 less by letting TEA CNC-port your heads? The AFRs have their applications, but you're nowhere close. You can reach your goals with the 5.3 heads you have, and nitrous, and a Jacobs Nitrous Mastermind. And a used LS6 intake. And headers. You go with a 200 horse nitrous kit, then set the jacobs to give you 50% of that down at 3000 rpm, and progressively increase to 100% at 6000 rpm. If you want to spend more, start with forged pistons, and file-fit plasma-moly rings gapped for nitrous. Want to spend more, and exceed 700 ft-lbs at the rears? get a pair of T4S04 turbos. They're perfect for a 5.3L, even better than a single T76.
Old 09-11-2009, 08:37 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Don't forget about the problem you'll have with the LM7 accessory drive, IIRC the LM7's idler pulley will be right in the way of the throttle body when using the F-body intake. You may have to go with F-body accessories or there may some companies out there that have a idler pulley relocation kit.
http://www.actionspeedshop.com/parts...duct_info.html
Hotrodboba400
12-10-2019 07:07 PM
db057
04-28-2019 07:45 AM
91L98Z28
Southern California Area
09-19-2015 09:35 AM
Bubbajones_ya
09-14-2015 08:38 PM
toronto formula
09-10-2015 07:31 AM
Quick Reply: LM7 plus FAST intake
