Do i need to get pushrods with a cam?
Old 08-23-2009, 02:17 PM
ranger77's Avatar
Car: 82 firebird
Transmission: i believe 200c
Axle/Gears: 3.43 Posi
Im trying to save money but are pushrods needed with a new cam??? My car has headers stock 416's heads. and 3701 intake. If anyone can suggest a good performance cam in which i wont need to replace my pushrods itll be very appreciated.
Edelbrock suggest the 3702 but i dont believe this will give me much performance compared to a stock camshaft.
Old 08-23-2009, 02:39 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Do i need to get pushrods with a cam?
well your last post said change the cam... no indication as to what so the assumption was that you were going to replace it with stock which wouldn't require new pushrods....
now you are talking a performance cam the further you go from stock the more likely it will be that you need longer pushrods...
as the increased lift of a performance cam comes from removing material from the heel of the lobe which makes the lifter sit lower in the bore requiring longer push rods to maintain rocker geometry...
no the edelbrock cam is an antique and wont provide the same increases that a newer grind from almost any other company will
Old 08-23-2009, 02:49 PM
ranger77's Avatar
Car: 82 firebird
srry to confuse you. You have helped me so much lol. TY for the replies. This is my last post. Lol
Prodigious
Theoretical and Street Racing
35
04-13-2021 02:37 PM
Jorlain
10-08-2015 01:57 AM
customblackbird
10-01-2015 04:30 PM
Strick1
09-04-2015 07:11 AM
z28guy134
09-01-2015 11:50 PM
Quick Reply: Do i need to get pushrods with a cam?
