RUNS GOOD WHEN COLD BAD WHEN HOT
Old 08-22-2009, 09:40 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
i have a 1990 camaro rs it sat for a few years. i replaced wires plugs fuel pump and the modual under the distributer. it also throws a code 43. When the is cold it will runs perfect. When it warms up it has no power and sputters. Anyone have any idea what the problem any imput would help!
Old 08-22-2009, 09:54 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
Re: RUNS GOOD WHEN COLD BAD WHEN HOT
need help badly
Old 08-22-2009, 10:59 PM
Rafs's Avatar
Car: 87 Firebird
Check your O2 sensor
Old 08-28-2009, 10:35 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
How do u jus check one without replacing it. But i dont think that is the pronlem any other ideas?
Old 08-29-2009, 12:46 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
At what temp does it start to run bad?
got a laptop, you can hook a computer up to them easy winaldl, only pricy part is if you buy the cable. but buildingit is easy but not, took two tries to get a good one built for me.
Old 08-29-2009, 01:50 AM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
Try and get a new ignition coil. I picked one up from auto zone for about 20 sumthing. Could also be bad injectors... but try that first.
Old 08-29-2009, 11:06 AM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
it dosent do it at any certain temp. i think it does it when it switches to closed loop. ive already checked the injectors and they were fine. Is there any way to make it stay in the open loop?
Old 08-31-2009, 11:48 AM
chevyfanman's Avatar
Car: 1991 camaro rs
Engine: tbi 305
Axle/Gears: its kinda low
my 5.0 rs does the same runs crazy fast in the mornings when its cold and drives like a dodge when it warms up and i also think my fuel pump whent out cause it spit and sputtered real bad last time i drove it
Old 08-31-2009, 03:04 PM
SpaniardV6's Avatar
Can be the water temp sensor located into the thermostate?
Try to get it and clean using a WD40.
I have in the past an Alfa Romeo 155 with a 2.0 Twin Spark and make the same problem that you V6, and was this sensor was sending a bad info to the ECU causing a bad mixture.
I think the best idea, is buy an ALDL wire into eBay, and conect your laptop to the car and get the data info to view the sensors value and get a good analysis.
Old 08-31-2009, 03:14 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
There's a way to datalog or whatever with the 1227302 ecm?
I'll have to try winaldl I guess. Can't do it with TunerPro. Hopefully my moates cable will work.
I had a similiar problem once with my 89. Replaced the ignition coil (in case there was a hairline crack letting moisture in), and the o2 sensor. Fixed it right up.
Old 08-31-2009, 03:15 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
I'd say, it's the fuel pump. I had a "friend" replace mine and It's done something similar ever since. Lemme ask you, when it gets hot is it like you hit the gas and it wont rev high? Does it go to like 2K then start to die? Because that's what mine does and I'm 99% sure it's the fuel pump. I also have a high pitched whine comming from the pump...
I don't have the time and definitley not the money to work on mine right now so I might have to let it stay this way untill next spring...
Old 09-07-2009, 12:50 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
i jus put in a new fuel pump and sometimes it does whine but it feels lik when it switches to the closed loop it doesent get enough gas. If you stomp it it jus sputters but if u jus barley stay on the gas it is fine. I think it is the knock sensor any ideas.
Old 09-07-2009, 01:59 PM
Poptart's Avatar
Car: '91 Firebird
Engine: V6
It seems like alot of questions on here deal with this issue. Im having the same problem. Everyone tends to find something that worked for them. A list of things I have either checked, replaced or am in the process of looking into are.
Fuel pump, Fuel return line, injectors, ignition coil, spark plugs, cap and rotor, fuel pressure reg, ignition module.
Try looking into those things.
Old 09-07-2009, 05:29 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
I put in a new pump, already checked the coil, put in new plugs, checked cap and rotor, and put in new module. any other ideas
Old 09-07-2009, 06:36 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
bump
Old 09-09-2009, 12:38 AM
Poptart's Avatar
Car: '91 Firebird
Engine: V6
If the fuel system is tip top as well as the ignition system then I'd almost have to say there is misread at one of the sensors. Id try what one of the guys above me said and get a read on the numbers running through the ecm.
I hope you figure it out cause it sounds like you have tried everything under the sun.
Old 11-25-2009, 09:57 PM
entrig00's Avatar
Car: 91 Camaro RS
Engine: 3.1 V6
Transmission: t-5
Anyone know what happen?
Is he up and running and what did he do to fix the problem or what was the problem...
I'm still going throu the same thing....
squiggy2
08-09-2015 09:30 PM
86Base
08-08-2015 01:34 PM
mustangman65_79
08-08-2015 12:07 PM
Quick Reply: RUNS GOOD WHEN COLD BAD WHEN HOT
