LT4 Hot Cam
Old 08-19-2009, 12:36 AM
Mauiblubandit's Avatar
Car: 1990 Formula 350
Engine: 350 tpi heads cam full exhaust
Transmission: 700r4 corvette servo and 2800 stall
Axle/Gears: 342 out of a 00 SS
LT4 Hot Cam
I have a 90 formula 350, I put a hot cam in it, and I was wondering what length pushrods to use if anyone knew????
Old 08-19-2009, 01:18 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: LT4 Hot Cam
Use the stock length and just make sure your rocker arms are all adjusted for zero lash. I'm assuming your engine is still a roller and therefore using hydraulic lifters.
Old 08-19-2009, 08:36 AM
3rdgenmaro's Avatar
Car: 88 IROC
Transmission: 700 r4
Re: LT4 Hot Cam
zero lash? i thought you only referenced lash while talking about solid cams. Ive always heard "preload" with hydraulic. If you just go to zero lash, you still need to preload the lifters.
Old 08-19-2009, 09:17 PM
Re: LT4 Hot Cam
3rdgenmaro it says you have a hotcam. Did you use stock length pushrods?? Do you have 1.5 or 1.6 rockers? What kind of springs did you use?
Old 08-20-2009, 09:42 AM
3rdgenmaro's Avatar
Car: 88 IROC
Re: LT4 Hot Cam
I used the stock pushrods that came in my motor. I started with a 97 vortec motor. Im using GM LS6 "yellow" springs. Currently Im running the stock stamped 1.5 rockers, but whenever money allows, Im going to go to some COMP 1.6 pro magnums.
Old 08-20-2009, 01:32 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: LT4 Hot Cam
The term "Zero lash" may seem like a misnomer, but it's actually the term that's used. It has a dual meaning - "Zero lash" and "Zero Preload" - they both mean the same thing. Sort of like "lifter" and "tappet".
However, Zero PRELOAD is the more accurate way to my way of thinking.
Jake
West Point ROCKS!
Old 08-20-2009, 01:56 PM
3rdgenmaro's Avatar
Car: 88 IROC
Re: LT4 Hot Cam
Jake
West Point ROCKS!
gotcha, thanks for the info
Old 08-20-2009, 02:46 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Zero preload implies you have not tightened them beyond contact, which is also not correct.
1 turn down of preload beyond zero lash is the factory recommended setting.
Old 08-23-2009, 11:54 PM
AT9305RS's Avatar
Car: 91 Bird
Engine: 3.1 w00t
Transmission: 7hundo
Axle/Gears: bent
Re: LT4 Hot Cam
i am currently helping MauiBluBandit get his car going, we tried using the stock length pushrods that came with the motor, which is a rebuilt L98.
The stock L98 pushrods were 7.200? They were WAY too long, so we have a set of stock LT1 pushrods in there now, and they seem to work much better? can anyone explain this?
Old 08-24-2009, 08:45 AM
rx8ss's Avatar
Car: 1987 Iroc Z28
Axle/Gears: 9 bolt
Re: LT4 Hot Cam
There could be several reasons.
Base circle of the cam could be different, deck hight differnences, valve stem hight differencs between heads, and others. That is why when changing a cam you should always check push rod length with an adjustable push tool. Just makes life easier.
Old 08-24-2009, 05:42 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Re: LT4 Hot Cam
[quote=JakeJr;4258485]The term "Zero lash" may seem like a misnomer, but it's actually the term that's used. It has a dual meaning - "Zero lash" and "Zero Preload" - they both mean the same thing. Sort of like "lifter" and "tappet".
Jake
Thanks for clearing that up for me Jake. Zero preload could be taken wrong, however, and a guy might not adjust the rocker arms down enough to zero lash or the point where there is just a bit of resistance and it becomes harder to turn the pushrods with the thumb and forefinger....zero lash, to me, means just that--tightened up against the top of the lifter and the bottom of the rocker arm. Some guys might think, "There's no lash, therefore, there must be space between the pushrod and rocker arm cup....not good. And to all who may have questioned my post, the guy wanted to know about what length pushrods to use and didn't ask about adjusting valves...that's why I didn't include more information on adjusting valves.....To add, once there is no lash, and the proper pushrod length has been determined, then the rocker arm nuts are to be turned 1/8 to 1/4 of a turn....any further could result in valves not closing all the way because these are hydraulic lifters we're talking about.
f-bodyz28
09-02-2015 05:03 PM
theurge
08-21-2015 12:46 PM
80s Poncho
08-19-2015 06:45 PM
1988iroc350tpi
08-14-2015 07:52 PM
anesthes
08-08-2015 09:37 PM
Quick Reply: LT4 Hot Cam
