my camaro will turn over but it won't start.
Old 08-13-2009, 09:08 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
can anyone tell me what the problem might be?, i don't own the car yet but im thinking at buying it if this is only a small issue
Old 08-13-2009, 12:52 PM
NINÅ's Avatar
Car: LOWERED ♦ CRIMSON METALFLAKE
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
USED CAR CAN’T GO FAR
It’s either not getting fuel or spark, or neither.
If it’s a TBI have a friend crank it while you look in the throttle.
If the injectors are squirting you will see it.
You can test for spark with a low cost spark tester available at any good parts/tools outlet.
There are cruder ways to test for spark however you will want one for future repairs/evaluations.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old 08-13-2009, 02:14 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: my camaro will turn over but it won't start.
Air, Fuel, or Spark. Almost always have air
bring a can of starting fluid with you and try cranking it after you spray a few shots; if it starts you know its a fuel problem. still no start - probably electrical. break it down to the basics and go from there.
Old 08-13-2009, 09:18 PM
Engine: L31 350
if this helps any it will crank all day but it just won't start, and its a v6
Spyder_TheGamer
12-25-2015 05:07 PM
92camaroJoe
08-13-2015 06:07 AM
ZsTransAm
08-11-2015 07:30 PM
Fronzizzle
08-09-2015 01:15 PM
BrianI
08-09-2015 11:52 AM
Quick Reply: my camaro will turn over but it won't start.
