my car wont shift untill extremely high rpm help!
Old 07-25-2009, 05:33 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Transmission: 700-R4
Axle/Gears: OSD 10 bolt/ 3.42
Recently my car has not been shifting efficiently
it waits untill beyond yellow and red line 5500, 6000, or above to shift out of first, and the same with 2nd.
when it gets to those rpms trying to shift, i have white smoke/haze entering the car from the center interior vents
could this be a bad trannsmission?
all the fluids are filled correctly
89 V8 305
any help would be appreciated
-Thanks
Old 07-25-2009, 07:34 PM
curacaoz28's Avatar
Car: 1985 Iroc-z28(sold) 1994 camaro z28
Engine: 350lt1
Transmission: 6-speed manual
Axle/Gears: ???
Re: my car wont shift untill extremely high rpm help!
what tranny do u have? it could be a broken or bad adjusted TV-cable
Or your vacuum line is out.
Old 07-25-2009, 07:44 PM
resinlake's Avatar
Car: 2011 6.2 Silverado, 88/85 camaro
89 V8 305
-Thanks
feel free to laugh but I should ask,
Is the accelerator stuck to the floor?
Old 07-25-2009, 08:33 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
lol, no
Old 07-25-2009, 08:41 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
um, i think the 700r4
how can i check what trannsmision i have?, lol noob question
i have to check the vacume lines tomarrow
Old 07-25-2009, 10:51 PM
resinlake's Avatar
dont worry about noob questions, everyones a noob in some respect to different technologies and such, like how I had to ask a question about my starters gear that was binding with my new flexplate and th350 I swapped in.
If you have 4 forward speeds, ya know the 1, 2, 3 and 4, you most likely 99% sure have a 700R4 and you doooo need a properly adjusted TV cable.
And no, I'm not going to tell you to search because I'm not a big fan of being told to do that my self, but I would suggest it
"To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the D button and pull the cable casing (the black tube) back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does."
https://www.thirdgen.org/forums/tran...ent-cable.html
Also... Inspect the cable, is it frayed, does it pull loosly, is it even attached to the hook inside the transmission?
IMO, it is part of why I like my th350, and yes I know, no over drive gear as someone will surely be quick to point out, but for me it is irrelevent because I do not need it and I sealed the detent cable with an expansion plug and black RTV sealant )
Oh the quote above, easier to understand in my opinion than the technical article on the site. Good Luck, please let us know how it turns out.
Old 07-25-2009, 11:05 PM
resinlake's Avatar
Oh and PB, while the TV detent cable is the first place to look I want to ask, is the governor stock, have you changed any springs/weights at all? If you find there is no problem with the detent cable (dont get worried about this yet) it could be some junk in the governor valve, weak springs, or possible some junk in the throttle valve in the tranny. Try the Detent cable first though, good luck!
Old 07-26-2009, 11:27 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
thanks for all the info, im going to have to do what you suggested tomarrow or the next day
to my knowledge, every thing is stock as far as springs and weights go
Old 08-01-2009, 12:23 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
finaly, me and my dad messed with the tv cable today, and after some tinkering, we drove it on the road and it shifted nicely...
thanks for all the info and help
-JOsh
Old 08-01-2009, 04:56 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I had that same problem and ended up rebuilding the tranny, installing, burned it up, rebuilt again. Then I realized how to set the TV cable.
I just hope your burning haze doesn't have some ill side-effect that will come back to haunt you. Congrats on the fix.
Old 08-01-2009, 08:45 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
i hope not to
i was determined to do whatever i could before i had to rebuild a tranny...luckily for me all it was was the tv cable
Old 08-01-2009, 10:24 PM
resinlake's Avatar
ahhh awesome, glad it worked out for you!!!
Old 08-02-2009, 09:39 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Is this at WOT, or just normal driving??
Old 08-03-2009, 12:12 AM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
it was at normal driving and very light acceleration
but its good now
Old 08-03-2009, 08:41 AM
Did it just go away, or did you have the problem fixed? I was gonna say as others did, it probably was the tv cable adjusted too tight.
Old 08-03-2009, 11:55 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
needed this info too.
Old 08-03-2009, 01:56 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
me and my dad fixed it ourselves by adjusting the TV cable
i was surprised something so small like a cable on the throttle could have such a big effect on the performance
Old 08-03-2009, 05:00 PM
Those tv cables control the tranny fluid pressure in the tranny. Glad ya found it. I adjusted my tv cable on my iroc a while back.
Old 03-24-2011, 04:18 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
I know this is a really old thread but im running into the same problem. I dont know what trany i have, all i know is its an auto with no overdrive( that i know of). Yesterday i was driving at some fast speeds with no problem, and this morning i drove it without warming it up( its a bit cold here) but she ran fine, but this afternoon after 2nd gear it would just stop shifting unless i hit at least 5k rpms. Is the tv cable adjustment different for different trans?
Azrael91966669
DIY PROM
25
06-20-2017 04:04 AM
Spyder_TheGamer
12-25-2015 05:07 PM
dhonda200
08-11-2015 11:50 PM
hokis
08-09-2015 03:57 PM
Sherpajames
08-07-2015 06:56 PM
Quick Reply: my car wont shift untill extremely high rpm help!
