Running engine with no AC refrigerant?
Old 06-22-2009, 12:41 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I'm almost ready to start my car after my H/C/I swap. I had to remove my AC system. I put the AC back in, but it's not charged yet. It's ok to run the car right? Just as long as I don't use the AC correct? I do not want to damage the AC compressor.
Old 06-22-2009, 12:58 AM
Hoffy91's Avatar
Car: 1982 Trans Am/1989 Iroc Z
Engine: T/A:1974 Corvette 350, Iroc:305 TPI
Transmission: T/A:Borg Warner 5-Speed, Iroc: Auto
Axle/Gears: T/A: Dana .44, Forgot Iroc
Re: Running engine with no AC refrigerant?
not a problem. Just dont turn A/C on. it will just act as a pulley, and will run the exact same as if it were charged but still off. Go fire it up!!
Old 06-22-2009, 06:29 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Until the A/C compressor clutch engages, it's just a pulley spinning freely with the rest of the accessories. However, since your system is empty, your A/C pressure switch should prevent the compressor clutch from engaging even if you do switch it on.
Old 06-22-2009, 11:02 PM
ericjon262's Avatar
Car: 85 2M6 Fiero, 06 2500 HD, 88 'burb
Engine: LX9, LQ4, L05
Transmission: F23, 4L80E, 700R4
Axle/Gears: 3.63, 4.10 14 bolt
thats right about the compressor not coming on without refrigerant in the system, the pressure switch won't allow it, it's been my fan overide for the past month and a half!
Old 06-22-2009, 11:57 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks guys! I'll hopefully have a video of it running this weekend!
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
Azrael91966669
DIY PROM
25
06-20-2017 04:04 AM
theshackle
03-05-2017 06:37 PM
bradleydeanuhl
08-12-2015 11:48 AM
Quick Reply: Running engine with no AC refrigerant?
