FUEL GAUGE STUCK ON FULL
Old 06-17-2009, 09:47 PM
blakecharles's Avatar
hello all,
I have a 1989 camaro RS v8 TBI 4 speed auto tranny...
anywho... the fuel gauge is stuck on full and will never move.
I took the face off and pushed the gauge all the way down to "E", then when I started the car it went all the way back up. I figured I had a full tank, but I have been driving this car for nearly a week without putting any gas in it. I KNOW ITS NOT FULL.
whats the problem? thanx n advanced.
Old 06-17-2009, 11:06 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Re: FUEL GAUGE STUCK ON FULL
Originally Posted by blakecharles
hello all,
The float affixed to your fuel pump in your gas tank is stuck.
It tells the dash you ALWAYS have a full tank.
You have to drop the tank, PB Blast/WD40 the float, get it to drop down.
And your golden.
Or you could just live with it.
Old 06-18-2009, 04:45 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
It's possible that the sender is bad,and is reading 90 ohms all the time,which it does with a full tank.Also check for continuity between the sender and the gauge,I think if you have lost continuity,it will also read at 90 ohms.Should be a tan wire.Good luck.
Old 06-18-2009, 09:17 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Before you go dropping tanks and performing all kinds of crazy unnecessary labor, DIAGNOSE it.
You can climb under the gas tank (if your car is stock 4WD height, it's easy), reach above and front of the differential and unpllug the 3-prong connector on the backseat wall.
Then take a paperclip and insert it in the connector half on the wall, in the two slots where the pink and black wires were (check the other half of the connector for wire color reference).
Turn the key on and check the gauge. If it reads empty, your gauge is good and so is the wiring fwd of the tank. If not, you have either a gauge or wiring problem. And you can take it from there.
Hope this helps.
Lou
The following 2 users liked this post by BigBadLou:
KR81 (05-30-2020), ughmas (10-26-2021)
Old 06-18-2009, 06:44 PM
thankyou everyone for all ur input. I will diagnose the problem and post the results shortly
Old 08-11-2009, 12:58 PM
undertow310's Avatar
did you find the problem with the fuel gauge was it a open circuit bad sending unit or what i got the same problem and it sucks running out of gas happen to me twice please reply your results or if any or if u havnt repaired it thanks buddy
Old 04-28-2010, 08:33 AM
badgerooster's Avatar
It seems to happen alot. Mine is full all the time. I'm going to check it electronically first. I understand if the float is stuck it will read full all the time.
One thing I haven't seen on here is a final conclusion. So lets see if I have this right.
Do the paperclip test for the guage. If guage drops to empty, then it's either the float or sending unit. Or is it just the float? Or it could be wiring to float/sending unit?
Any case beyond guage or ground being bad you would have to drop tank to correct it.
Not a wiring genius either but if I take my multimeter and get 90 ohm reading then it means what?
Not afraid, just fixing other things first and 1st time 3rd gen owner.
Old 04-28-2010, 08:40 AM
Please reply to above post. Of the people who had this and fixed it. What was it? Which happened the most, float, ground, guage or what.
I'm justing getting into this car and most of the time vehicles have repeatable problems. Just trying to work smart.
Old 04-28-2010, 09:09 AM
SSZ2891's Avatar
ive got the same exact prblem
Old 05-02-2010, 01:09 PM
1990z28's Avatar
Car: 1990 Z28 Camaro
I have the same problem also I did check the wiring and I used the paper clip and it went empty if I have to drop the tank what is the easiest way to do so.
Old 06-19-2010, 09:28 AM
kitt23's Avatar
im having the same exact problem with my firebird
Old 06-19-2010, 10:45 AM
8720th's Avatar
Car: 87 iroc-z
Engine: B2L
Transmission: 700-R4
Axle/Gears: 3:27
you gotta pull the rear end to drop the tank sorry to break the bad news it really sucks but thats the way man i got the same issue with my iroc and its annoying
Old 06-19-2010, 05:15 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
The way the fuel gauge works is some what like a game of electrical tug of war. Without getting into too much detail on that basically how it works is as the resistance increases so does your fuel level according to the gauge and vice verse. What 99.9% of the time causes your issue is an open circuit. This makes scene because an open circuit is essentially infinite resistance which would correspond to an infinitely high fuel reading (pegged). The opposite would be shorting it to ground with the paperclip trick mentioned earlier makes the resistance 0 and the fuel level should also read 0 indicating the gauge itself works. To troubleshoot this I would start at the gauge itself. I would remove the fuel gauge and measure the resistance to ground of the contact that connects to the fuel level sensor. Now your meter could show a multitude of things or just nothing at all. If the meter is unresponsive this means you have an open circuit and will need to track it back. Could be a bad connection a broken wire bad sender ect. If you get any resistance withing the normal range of the sensor (including 90 ohms) it means that either the gauge itself has an open circuit internally, a bad connection from the dash to the gauge itself, or in case of some constant high reading around 90 the sensor may be just jammed up.
Old 06-22-2010, 09:42 PM
8720th's Avatar
Car: 87 iroc-z
Engine: B2L
Axle/Gears: 3:27
ok i gotta question idk how to start a thred on here ive been on this website for yrs and just became a member im on my 4th 3rd gen now and i got a used msd 6al box and idk wtf to hook the white wire up to??? its the single wire for timing excessory to tell the box to spark so my damn car will start i got it hooked to the battery and to the coil and got a great key on power and this is the last step and i need help please some one help me im lost as hell and the summit tech line guy told me its not used on my car well um hey dumbass how does my pick up coil tell it to fire if its got no signal lol
Old 06-22-2010, 10:07 PM
1990z28's Avatar
I dont mean to sound like a ***** but the new thread button is like the Reply button on and subject list and everything. But I dont know bout you prob but SEARCH IS YOUR BEST FRIEND its in the top bar if you did not know. I wish I could help you on that. But try to keep the post on topic.
Old 06-22-2010, 11:34 PM
sorry I stopped posting guys. I'm the OP, I never fixed my gauge problem. I'm in the process of taking everything out and prepping for a LSx swap.
Old 06-23-2010, 09:46 AM
SSZ2891's Avatar
Hope this helps.
Lou
so i just did what bigbadlou said and when i inserted the paper clip into the two slots my gauge dropped even farther past full. what does this mean? what should i check next
Old 06-23-2010, 01:31 PM
NINÅ's Avatar
Car: LOWERED ♦ CRIMSON METALFLAKE
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gage Rage
In addition to the info BigBadLou supplied, you can test the gage by removing the sender wire at the gage.
Use a potentiometer with a value of 90Ω or the closest you can find.
Connect one end the potentiometer to the gage from the location you removed the sender wire.
Connect the wiper of the potentiometer to ground.
Turn the key to RUN.
Slowly adjust the potentiometer from 0Ω to 90Ω.
If the gage is bad it will exhibit the problem you have.
If the gage is good it will display a smooth transition from one end of it’s range to the other.
To find out if the sender is working measure between the sender wire and ground with an ohmmeter.
It will read between 0Ω and 90Ω if it’s OK.
0Ω = Empty, 90Ω = Full
Happy Racing!
Does The White Flag Mean He’s Surrendering?
Old 05-24-2011, 09:59 PM
marks83z's Avatar
Car: 83 camaro z28
Engine: 350 cfi, soon to be 383 tpi
Transmission: turbo 350, soon to be 700r4
Axle/Gears: embarrassed to say,ford 9 inch soon
im not sure if any of yall are still around since this is an older thread but any ways, my gas gauge stays pointed past full most of the time, when i bought the car to drive it home i said hey, i got a full tank. but after 2 miles the needle started shaking around E and another mile or so later the car shut down. so, stays past full untill it runs completely out. any ideas?
Old 05-25-2011, 08:29 AM
kitt23's Avatar
Yes you have same problem as me. Your fuel sending unit is bad. You need to replace that and you might as well change your fuel pump since you have to drop the tank I believe
Old 05-25-2011, 04:13 PM
mrrman's Avatar
me to, in my 87 TA
Old 02-02-2013, 06:24 PM
asm383's Avatar
Car: 91 z28 convertible
Engine: 350lt1
Hope this helps.
Lou
whats happens if it goes to full instead of empty?
Old 02-02-2013, 08:01 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You mean when you do the test?
Old 02-02-2013, 08:26 PM
asm383's Avatar
Engine: 350lt1
Yes
Old 10-25-2021, 09:41 PM
LaurieKe's Avatar
Hope this helps.
Lou
This was originally posted a long time ago, but I'm giving it a shot. I bought my car new. It has a digital instrument cluster. Last fall a shop put in a new fuel sending unit and the gauge has read full ever since. I tried this yesterday with my boyfriend. I knew better, but he said start it and I did, he got shocked and now the car cranks, we can smell gas, the cluster lights up, he checked the fuses, spark plugs and wires, distributor. It won't start. Any ideas? He told me to get a fuel pump relay. I'm looking in the Haynes Manual at the wiring diagram and it shows that this plug leads to the voltage regulator HELP!!!!
Old 10-25-2021, 10:32 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Consider starting a new thread for your no-start issue; most likely it isn't related to the fuel gauge reading full. I'm not sure I follow the diagnosis that took place. The car wasn't turning over, then your boyfriend got shocked by (something?), and now the car is turning over? When was the last time the car was running?
Old 10-26-2021, 12:32 AM
LaurieKe's Avatar
The car was running 5 minutes before. The fuel gauge has been stuck on full for a year. We were trying to find out if the problem is the gauge or the fuel sending unit. After the paperclip bypass and the shock, now the car won't start. It turns over, the engine is getting gas - can smell it, the fuses, spark plugs and wires seem okay. The fuel gauge still said full. I started from this string, because that's what we were doing, and that's where the problem started.
Old 10-26-2021, 01:33 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Ah, I didn't get the context that 'this' meant you tried the quoted diagnosis. Did you check the fuse in the engine bay? It might be near the battery, one of the wires going to it should be ORG.
Old 10-26-2021, 01:47 AM
COTM Editor
QwkTrip's Avatar
Received 1,855 Likes on 1,270 Posts
Car: '89 Firebird
Engine: 7.0L
You can't get shocked with 12V. It's not enough voltage to get through your skin. You can get burned from the heat of a short circuit though, like when you put a paperclip where it doesn't belong and short to ground.
So.... where did he poke that paper clip? That's when your problem began, right?
Old 10-26-2021, 05:05 AM
OrangeBird's Avatar
Car: 1989 Firebird
Hi LaurieKe, first and foremost, what kind of car are we working on? Knowing what you've got may well help in the diagnosis.
And I'll bet Komet nailed it, your boyfriend likely shorted the fuel pump rather than the fuel gauge, to ground and likely blew the fender mounted fuse. Although you shouldn't be able to smell gas if that fuse is blown, I'd still be checking that given what caused the no start.....
Old 10-26-2021, 01:47 PM
LaurieKe's Avatar
I suppose that would help
1987 TA, 5L V8 fuel injected.
The fuel gauge was, and is still stuck on full. That seems like a minor issue now.
I have ordered a fuel pump relay and an ignition module. Also, found that the ignition terminal connector was broken. Will check the fender fuse. Thanks!
if you have one and are "saving" it and not driving. It's a bad plan. I have 87,000 miles and am starting to spend a lot of time at the parts store.... if the parts aren't discontinued.
Old 10-26-2021, 02:17 PM
COTM Editor
QwkTrip's Avatar
Car: '89 Firebird
Engine: 7.0L
You have wiser insight than most people. Yep, old cars are always teetering on a fine line between being nice and going to crap. It takes waaaaaay more effort to keep an old car nice than most people realize. And it goes downhill really quick if you get complacent at all. Lots of time, lots of money, sometimes wonder why I do it.
T.L. (10-26-2021)
Old 10-26-2021, 02:54 PM
vorteciroc's Avatar
Voltage can be quite low... lets say 1.00 Volt (not enough to feel a shock), but if enough Amperage is present...
You WILL get Burned.
Some high-performance PC Processors will operate in the 1.00 to 1.50 Volt range...
But draw 400 to 500 Amps, and will most definitely burn you.
On the other hand, 50,000 Volts from an Ignition Coil will give you a mild Shock...
But the Amperage is very low (1.00 to 10.00 Amps depending on saturation) and will not Burn you.
Old 10-26-2021, 03:05 PM
vorteciroc's Avatar
I will regret this until I die...
About 10 Years ago, my best friend was killed helping me at the Race Track.
My Race Car at the time used Six 12 Volt Batteries (in a Series-Parallel arrangement) to power the Starter-Motor.
The Battery Bank sat in the Bed of a Pick-Up Truck and used long Cables to connect to a hand-held Starter Motor.
It connects to the Supercharger Pulley to start the Engine, then is removed from the Engine.
After a pass down the track...
the Crew (and my friend) would ride in the Bed of the Truck to tow the Race Car back to the Pits.
While in the Bed, my friend dropped a large wrench across the Battery Bank...
The combined Voltage and Amperage Potential of the six Batteries sent him about 6 feet out of the back of the Bed...
Landed directly on his Head, and that was the end.
Minor burns were visible on his hand/ arm... but the power stored in the batteries both shocked and launched him off of the Truck.
I miss you Brother! RIP.
Old 10-26-2021, 05:30 PM
COTM Editor
QwkTrip's Avatar
Car: '89 Firebird
Engine: 7.0L
That's heartbreaking. What voltage was it at?
If you don't want to talk about it any more totally understand.
Old 10-26-2021, 05:57 PM
vorteciroc's Avatar
The Meter on the Starter-Motor would show 72 Volts and 3,200 Amps during cranking.
The potential of the 230,000+ Wattage sent Him flying.
Old 10-26-2021, 09:23 PM
vorteciroc's Avatar
Thank you.
You are absolutely correct.
I immediately jumped down to the ground.
On the ground, I could feel that he was not breathing...
But that his Heart was beating very quickly.
I immediately tried to give him CPR, but a second or two later...
blood was pouring out of his Mouth, Nose, Eyes, and Ears...
It was too late; his Brain was badly injured.
By the time my crew pulled me off of him, to stop me from continuing CPR...
I was completely covered in my friend's Blood.
At the time, I had no idea that the human body contained so much Blood.
Damn, I feel horrible about this... to this very day.
ThirdGen84Coupe
06-24-2019 11:59 AM
RK82
03-25-2008 10:57 PM
Dante93GTZ
08-15-2003 02:57 PM
89RsPower!
05-11-2003 06:46 PM
BAK12484
10-15-2002 10:47 AM
Quick Reply: FUEL GAUGE STUCK ON FULL
