ok bought an HEI distributor how do i hook it up?
Old 06-16-2009, 10:32 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
I bought one of the summitracing HEI distributors with the built in coil in the cap.
found here:
http://www.summitracing.com/parts/SUM-850001-2/
do i need the 2 wire connector or the single wire connector and where do i hook up my autometer tach? Im thinking i need the dual wire b/c of the ignition and tach...
2 wire connector:
http://www.summitracing.com/parts/ACC-170072/
single wire connector:
http://www.summitracing.com/parts/SUM-G5210/
thanks chas
Old 06-17-2009, 07:00 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Re: ok bought an HEI distributor how do i hook it up?
You want the dual connector. The red wire goes to a switched ignition source. The other one goes to your tach.
Old 06-17-2009, 11:41 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
sweet thanks a million
Old 06-17-2009, 01:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need a fairly heavy wire for the switched power source. Something like 10 gauge. No thinner than 12 so don't attach a thinner wire to the pigtail.
Old 06-17-2009, 01:31 PM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
summit also has the adapter wire for power and tach..it plugs into your old one an then to the new dizzy so there is no splicing
Frozer!!!
01-19-2024 04:55 PM
midge54
01-29-2017 07:00 PM
stalkier
08-21-2015 01:54 AM
midias
08-15-2015 05:07 PM
stalkier
08-07-2015 04:49 AM
Quick Reply: ok bought an HEI distributor how do i hook it up?
