MAF burn off relay location?
Old 06-14-2009, 07:21 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Where is the MAF burn off relay located on my 1988 IROC-Z? I have a code 36 that comes on once in awhile, I have replaced the MAF and the wire connector. In order to do some additional troubleshooting I will need to locate the MAF burn off relay. Thanks, Andy
Old 06-14-2009, 10:55 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: MAF burn off relay location?
Check behind and to the right of the Brake Booster, on the firewall. Should be three relays there. Burn Off should be the one closest to the Brake Booster.
Old 06-16-2009, 02:22 PM
ANDYZ28's Avatar
Car: 1982 Z-28
OK thanks I'll check it out tonight
my86bird
10-23-2015 12:20 PM
Gunsbee
09-07-2015 07:10 PM
WickedBowtie
Exterior Parts Wanted
09-05-2015 04:58 PM
tonys91rs
09-02-2015 07:07 PM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
Quick Reply: MAF burn off relay location?
