anybody spray por 15?
Car: 1994 Pontiac Trans Am
Transmission: auto, but i want a T56
has anybody had any success spraying por 15 through an hvlp gun? if so what tip size did you use, and did you have to thin the paint? I want to spray my engine bay with this stuff. I ordered a gallon of the semi gloss black to do my floorboards (top and bottom). I'm probably going to brush those, unless spraying goes well if its even possible.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: anybody spray por 15?
even por 15 doesnt reccomend spraying it. they say you do need to thin it.
por15.com
i would count on not being able to use the gun for anything else after that.
por15.com
i didn't notice that on their website before. i just read you need to thin it with their thinner made specifically for por 15 and i don't wanna spend more money on that, so... i guess i'll be brushing it on. i wonder how it's going to turn out
anybody have suggestions on getting a smooth finish while brushing. i know sanding is going to be difficult in a few areas under the hood.
dont worry about sanding too smoothly, it does cover pretty well. use as litlle paint as possible and clean up drips and runs w/ a seperate unloaded brush for smoothest results. have lots of disposable brushes available in case you contaminate one or it becomes too loaded. i use the foam, as this stuff tends to eat most cheap bristle brushes and sheds in your paint.
thanks for the tips i'll post pics when i paint it. i still need to pull the engine and everything else in the engine bay.
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
if you shoot por 15 wihtout a full body suit and a fresh air supply system in your mask, you will die sooner then you should have. brush it on.
Car: 84 olympic edition camaro
Engine: 2.8
I sprayed a truck frame with it and it turned out perty good. I just used a cheap sears paint gun and a good mask, though I didn't have a fresh air supply. So far its been 3yrs and the only problem with it is its chipping in a few places.
HoosierinWA
10-07-2015 10:15 AM
