Inertia Switch?
Old 04-30-2009, 09:57 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
Inertia Switch?
My fuel Pump on a 1990 camaro Rs will not kick on. New pump, and new relay so only other thing i can think of is a inertia switch. Does anyone know if that car has 1 and if so were is it located.
Old 04-30-2009, 11:03 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
Re: Inertia Switch?
Inertia switches are a F*rd thing.
Anyhow - check the power wire all the way to the back. If you've got power on the (pink? damn - not looking a dwg) wire at the back, then check the ground. Does your fuel gauge read right? They share a ground.
I've had a case where the fuel pump power wire was actually broken INSIDE the insulation! Took me forever to track that one down, since everything LOOKED like it was OK. Kept probing the wire every foot or so with a fine pin. Eventually the power disappeared, and I just worked my way back. Good tug on the wire, and it snapped in two.
Veaceonee
09-29-2016 08:15 PM
RacerM
09-28-2015 04:25 PM
tglennon11
09-23-2015 05:30 PM
327IROC85
09-23-2015 12:11 AM
Randomtask2
09-10-2015 08:37 AM
Quick Reply: Inertia Switch?
