roller rockers
Old 04-28-2009, 01:59 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
roller rockers
I have a stock 87 350 TPI, rockers are 1.5 stock.
Would the 1.6 make somewhat of a diff, meaning is it worth the money?
What stud size would I need if I were to consider this?
Old 04-28-2009, 04:43 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
"Somewhat of a difference" is a pretty good way to put it. "Worth it" is probably not a good way to put it.
The rockers are available for both 3/8" and 7/16" studs. You don't have to change studs to change rocker ratio. That's more about high spring rates and high RPMs, rather than rocker ratio.
You'll get more benefit out of a full roller rocker like Comp Pro Magnums than just a change from 1.5 to 1.6. But, that again probably doesn't fit in the "worth it" category.
Old 04-28-2009, 06:59 PM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
Re: roller rockers
yea you wont see much of a diff but get full roller 3/8 stud 1.6 ratio self align be shure there self align i think only jegs and perform and i think comp make a set of the self align .
Old 04-28-2009, 07:49 PM
f1aws's Avatar
Re: roller rockers
will the 1.6's clear the stock valve covers?
Old 04-28-2009, 08:49 PM
Car: 87 iroc z
Engine: 358 tpi
Re: roller rockers
no kind of roller rocker will clear the stockers i had to get a set from jegs they were 100 bucks and look pretty damn good plus there aluminum look at my pics and youll see them
Old 04-29-2009, 11:16 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
Re: roller rockers
not even narrow roller rockers?
Old 04-30-2009, 03:27 PM
3rdgenmaro's Avatar
Car: 88 IROC
Transmission: 700 r4
Re: roller rockers
Wouldnt be worth it to me on a stock motor.
If you do though and you put alot of miles on the car, go with the Comp Cams steel ones. Aluminum will break eventually.
Old 04-30-2009, 03:40 PM
87350IROC's Avatar
Car: 87' IROC
Re: roller rockers
Not true. I run Comp Cams 1.5s and they clear the stock valve covers with a little trimming to the valve cover center bolt support.
Old 04-30-2009, 04:15 PM
Car: 87 iroc z
Engine: 358 tpi
Re: roller rockers
ohh yea cool i never tried just thought by looking theres no way
Old 04-30-2009, 05:08 PM
Heslekrants's Avatar
Car: 1990 Camaro RS
Engine: 5.7L Vortec TBI
Transmission: Built 700R4 2800 stall
Re: roller rockers
Going from 1.5 to 1.6 rockers will give you some extra power. It's like putting in a slightly bigger cam without all the work. Going with a roller tip vs full roller depends what you're planning on doing with the car. Your factory studs should be 3/8.
The roller tip rockers will fit under your valve covers and are good for mild applications. I ran a set for 70k miles & they were still in great shape.
The full roller rockers are for more high performance use and have more clearance issues (valve covers, springs, pushrod length).
Old 04-30-2009, 06:04 PM
transamice's Avatar
Car: 87 GTA t-top
Re: roller rockers
Honestly just trying to free up some more power with what I got.
Im almost at my sweet spot with my car, I think with a few more simple mods and tweaking I will be pleased.
Just mainly for cruising and take to the track once in while.
KO1
16
10-15-2015 05:00 PM
Agent507943
Firebirds Wanted
10-02-2015 07:18 AM
92projectcamaro
09-29-2015 07:07 PM
dusterbd
09-29-2015 08:40 AM
tcarlos13
Interior Parts Wanted
09-28-2015 06:31 PM
Quick Reply: roller rockers
