Alternator Amps
Old 04-27-2009, 12:10 AM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Alternator Amps
How many Amps does the alternator for a 88 350 TPI put out? Im going to replace it and need to know if i should get one with more amps out of it or keep it stock
Old 04-27-2009, 01:14 AM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
Re: Alternator Amps
that is your call, although it would be nice to have more Amps to run your sub. th Alternator will only generate the power that is needed, it will not over generate (as long as the regulator works properly)
Old 04-27-2009, 03:00 PM
crytical point's Avatar
Car: 92 RS Camaro
Axle/Gears: 3.08
Re: Alternator Amps
Stock should be 105 but that is ***** out and at idle will make like 40-50.
I bought my 220Amp from www.springhillautoelectric.com and that man works out great prices and will custom make them. I got the 220 with overdrive pulley and large post for $230 and he custom builds per customer and ships fast.
Old 04-28-2009, 01:14 AM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Re: Alternator Amps
Damn only 110? that sucks, is powermaster a good brand? I notice there is a significant voltage drop when the cooling fans kick on and also turning up the sub on my car
Old 04-28-2009, 02:27 PM
Car: 92 RS Camaro
Axle/Gears: 3.08
Re: Alternator Amps
Powermaster is a good brand but expensive
http://store.summitracing.com/partde...140+4294908198
http://www.springhillautoelectric.co...d&productId=68
365$ gets you 200amps and a 1 year warranty
215$ gets you 220amps and a 5 year warranty
If it was a small difference I would make a big deal but $150 is alot and for less.
Old 04-29-2009, 11:48 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Alternator Amps
What are you running for amplifiers? One sub, one amp is not going to really do all that much damage on a stock alternator. My last Camaro had 2 class a/b amplifiers (one for components, one for sub) and never had any dimming issues. If you're running a newer sub amp thats class-d (80+% efficient compared to the 60% or so class a/b), you should have no problems.
Old 04-29-2009, 11:56 AM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Re: Alternator Amps
And if you really want to be on the safe side, add some capacitors.
Old 04-30-2009, 12:56 AM
Car: 92 RS Camaro
Axle/Gears: 3.08
Re: Alternator Amps
Capacitors are just bandaids and are far from safe (watched a brand new one burn a car to the ground). If you just upgrade your alternator you will have no problems and all your lights will be brighter and it will give you room to build up.
I was running two a/b amps on the stock alternator with big 3 and my lights would still dim until I got it over 1500. But I would try and get it done right with a new alternator, big 3 wiring, and a optima battery or any other deep cell.
Old 04-30-2009, 06:46 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Alternator Amps
I completely forgot to mention the "big 3" upgrade. Definitely will help and least expensive upgrade of everything mentioned so far.
Old 05-05-2009, 01:27 AM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Re: Alternator Amps
I only have a 1000 watt amp, 1 phoenix gold 10, and my aftermarket deck, thats pretty much it, without going into any detail whats the "BIG 3"
Old 05-05-2009, 05:50 AM
bald_noggin's Avatar
Car: 1971 GM Holden, HQ GTS Monaro Coupe
Engine: Gen I 350 Chev soon to have TPI
Transmission: TH400
Axle/Gears: Going to be a 3.55
Re: Alternator Amps
Big Capacitors (1 Farad or larger) are good for sub-woofer amps. Especially when your cranking the audio up and you're pushing some big bass.
Really big audio systems have the ability to drop the cars voltage down to a point where the audio head unit or amplifiers reset themselves. The problem being that a when a big bass transient comes along, the alternator's regulator can't respond quick enough to compensate for the sudden increase in current it needs to provide and as a result of this increase in current demand, the voltage drops. The capacitor acts like a big instant reservoir for current and can supply enough to get past the bass transient which may only last milliseconds.
So unless you have a really big system, a stock alternator will do fine and you should not need a capacitor.
Big capacitors, when charged can be as dangerous as charged car batteries. You don't want to go short circuiting them! They can arc, overheat, damage themselves and cause flash burns.
Mind you, that's not to say that you can't have some fun! Check this out:
http://tesladownunder.com/CanCrushing.htm
He uses capacitors from a heart defibrillator! It's worth the read even if it may be technical.
Old 05-05-2009, 07:20 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Alternator Amps
The Big 3 refers to the main power wires you have under the hood; negative battery to chassis (ground), positive battery to alternator, and engine block to chassis (ground). For most people, 4ga would be more than adequate, especially considering stock in these cars is usually 8ga or smaller. For this kind of job, I usually pick up a 4ga amp wiring kit, as you'll get more than enough to do all 3 and then have leftovers. Feel free to run it in addition to what you've got now, as it won't hurt to keep the old stuff in place. Personally, and its not required, I always like to fuse the positive to alternator wire for safety sake.
Old 05-23-2009, 01:18 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Re: Alternator Amps
Is there anyplace online i can get the 4gauge wire kit for my Fbody?
apie2546
10-16-2016 02:24 PM
SRKLEGIN
10-29-2015 06:38 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
SRKLEGIN
10-03-2015 10:11 PM
raymondandretti
09-27-2015 06:43 PM
Quick Reply: Alternator Amps
