Fuel pump won't shut off....
Old 04-12-2009, 10:04 AM
dave7310's Avatar
Car: 91 Firebird
Pulled my '91 bird (3.1 v-6) out to get it ready for summer. The fuel pump stays running after the key is turned off. It's cold outside and I feel like crap so I just parked it and pulled the battery cable off for now.
Stuck relay maybe??
Old 04-12-2009, 05:57 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: Fuel pump won't shut off....
Either that or thick oil. How long does it run when you turn the car off?
Old 04-13-2009, 04:26 PM
dave7310's Avatar
Car: 91 Firebird
It ran for 10-15 min until i pulled the battery cable.
Thick oil? i was looking at the wiring diagram in the factory service manual and saw the oil sending unit was in the circut at the ECM.
Does the sending unit control the fuel pump in some way?
Old 04-13-2009, 04:43 PM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
this is an electric in-tank pump, right?
if so, it's prolly gonna be a stuck fuel pump relay. take a hammer and tap it, plug it back in, and see if it still runs after that.
what does the oil have to do with the fuel pump????
Old 04-13-2009, 04:59 PM
bald_noggin's Avatar
Car: 1971 GM Holden, HQ GTS Monaro Coupe
Engine: Gen I 350 Chev soon to have TPI
Transmission: TH400
Axle/Gears: Going to be a 3.55
When you shut your car down, try turning the ignition back on but don't start the car. Does the oil light come on? I ask this because it's a common switch for the driver oil pressure warning lightalso also providing 12Volts for the fuel pump.
The fuel pump is switch to run once the oil pressure sees a certain amount of pressure. It should kill the pump when the motor stops because the oil pressure disappears.
You problem is more than likely, the oil pressure switch or the fuel pump relay.
Cheers,
Col.
Old 04-13-2009, 05:15 PM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
oh, kool. i learn something everyday!
Old 04-13-2009, 05:40 PM
dave7310's Avatar
Car: 91 Firebird
Thanks guys,
I 'll check them both. I put a new sending unit in 3 years ago when i bought her ( gauge didn't work ) so i'm thinking it's the relay.
But ya never know...could be the new sender ?! lol
92camaroJoe
07-29-2023 07:57 PM
Glowsock
08-02-2020 07:36 PM
92camaroJoe
08-13-2015 06:07 AM
djmarch
08-09-2015 05:27 PM
Quick Reply: Fuel pump won't shut off....
