How much HP can a 350 TPI Fuel Pump support?
Old 04-01-2009, 09:08 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I'm in the process of a 406 build and I am wondering how much Horse power the stock fuel pump can support? How many gph will if flow??? I did a ton of searches and have had not luck with finding info on a 350 TPI FP
Old 04-02-2009, 04:08 PM
Car: 89 Formula 350
Re: How much HP can a 350 TPI Fuel Pump support?
ttt
Old 04-02-2009, 05:43 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Supposedly 400-450hp.
Old 04-02-2009, 08:14 PM
Car: 89 Formula 350
Thanks... Hope that will be enough
Old 04-02-2009, 08:43 PM
Guest
Guest
Posts: n/a
The stock pump is rated at 40gph (150lph), I presume at 45+PSI. The shutoff pressure is above 65PSI so it should supply enough pressure for the flow rate at what its rated at.
Old 04-02-2009, 08:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
you can upgrade to a hotwire kit from racetronix and push more voltage at that pump and get more fuel out of it. But it may shorten the life of it.
Old 04-02-2009, 11:23 PM
Car: 89 Formula 350
yeah I might try that and see how it works. How much is $ that? Do you know the part #? and how much more HP it help my fuel pump support? Thanks again Orr89RocZ you have alot of good info!
Old 04-02-2009, 11:33 PM
3rdgnberlinetta's Avatar
Car: TRUE BERLINETTA
Engine: 5.0 CARB. ALL DAY
Transmission: 700 R4 TURBO
Axle/Gears: 373 BURN N DWN THE TRACK
worst thing u can do is push it,best thing to do is change. holley electric blue pump is top of the line we run this same one n a 555 supercharged with nos and it dumps fuel easliy.they are no more than 200 bucks but worth it,the stock fuel pump preety much max's out where it is now,it can handle more but u dnt wonna have it go out at the wrong time if its pushed to hard.i just chmaged mine because i was on my 3rd one in 6 months but i also push my camaro lke theres no tommorow
Old 04-03-2009, 05:57 PM
Car: 89 Formula 350
ok, i'll see what happens after I drop the engine in. Its not the price of a fuel pump, its I just dont really want to drop the rear
Old 04-03-2009, 06:15 PM
doc
doc's Avatar
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
40 gal/hr translates to about 248#/hr fuel flow rate. Therefore,
engine Hp = (Fuel flow rate) * DC / BSFC = 248 * 100% / 0.5 = 496 Hp
This 496 Hp is achieve with absolute maxed out injectors. Realistically, 450 Hp.
Old 04-03-2009, 06:50 PM
Car: 89 Formula 350
What would u guys guess on the horse power of a 406 with comp XE284 cam(240/246 .507/.510), Brodix 200IK heads, Super Ram w/30lb injectors ??
Old 04-03-2009, 07:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
probly 450hp
Old 04-03-2009, 09:40 PM
Car: 89 Formula 350
probly 450hp
is that ur guess for flywheel or rear wheel HP?
Old 04-03-2009, 10:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
flywheel. you'll be closer to 380-390 whp i'd say. Do have a decent cam/heads setup so it may touch 400
Old 07-02-2010, 10:35 AM
tslsa28's Avatar
Car: 91 RS and Jaguar XJS
Engine: ZZ383 with Mini Ram
Transmission: Tremec 3550
Axle/Gears: 3.42 with Tru Trac
Doc, Will fuel pressure effect your calculations? I used to run 32 lb injectors at 45 lbs fuel pressure on a ZZ383 making about 390 rwhp. The stock fuel pump wouldn't keep up during the dyno tuning so I went to Walbro's 255 lph fuel pump. Now I have 42 lb injectors at 40 lbs fuel pressure. Will the stock fuel pump keep up at the lower fuel pressure? I'm asking beacause the Walbro high flow pump seems to cavitate on very hot days at part throttle if I'm driving for a long time. My theory is the high flow fuel pump flows so much fuel back to tank right at the fuel pump at low loads, it is heating the fuel pump or causing turbulance around it. The stock pump will return less and may fix this problem.
Old 07-02-2010, 04:06 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
i had to also put in a 255lph fuel pump. The stock one would not flow enough
Old 07-02-2010, 04:50 PM
tslsa28's Avatar
Thanks. Sounds like I need to stay with the high flow fuel pump. I think everybody is using the Walbro and they seem to make about the best high flow pump for our cars.
Old 07-02-2010, 08:03 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Works for me no probs.
410RWHP 383
92camaroJoe
07-29-2023 07:57 PM
Grant2k
07-10-2018 04:01 PM
theshackle
03-05-2017 06:37 PM
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: How much HP can a 350 TPI Fuel Pump support?
