Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Mini Ram with Accel 1000 CFM Throttle Body?
Old 03-27-2009, 02:04 PM
scottwrightF1's Avatar
Car: 1988 Camaro Iroc / 1989 Firebird TA
Engine: Camaro 350 cid / Firebird 305 cid
Transmission: Soon T56 D&D Viper (WC T5) / WC T5
Axle/Gears: 9 bolts; 3.45>3.89 / 10 bolts; 3.08
Please, I need an answer for my 1988 Camaro. I have a Mini Ram and I think it a ACCEL 1000 cfm Throttle Body. I have not set it up yet in my car.
I was wondering will my throttle body fit the Mini Ram?
Let me know thanks.
Old 03-27-2009, 02:10 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Re: Mini Ram with Accel 1000 CFM Throttle Body?
Yes it should, my Miniram when it came from TPIS was made for a 58mm TB. Im running one of TPIS 58mm TB's and its a perfect fit.
Old 03-27-2009, 02:27 PM
Thanks, but the TPIS TB and the ACCEL 1000 cfm TB have a different shape design. So I was not sure if the ACCEL would fit my Mini Ram. So if that is the case it would fit.
Thanks again.
Old 03-27-2009, 02:34 PM
Randy92Z's Avatar
Engine: Miniram 383
I may have misunderstood your question, Yes, ANY TPI style tb, will bolt up to the Miniram intake. I thought you may have been asking about if the 58mm openings will "line up" with the oval opening in the intake and cause flow restrictions.
EDIT: you will have to cut-off the coolent ports on the bottom of your TB if it has them.
Old 05-15-2009, 07:24 AM
fastsspr's Avatar
Car: 1985 Yellow Iroc Z w/LS interiors
Engine: 305ci 5.0L
Yes it fit.Years back i used a MR in my car with the accell TB with no problems.
Old 05-15-2009, 01:58 PM
Thanks, I was doing a lot of research and couldn't find any answer to it. So thanks.
Old 05-15-2009, 08:30 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
i believe the 58mm throttle body flows 1100 cfm, enough for any screamin smallblock
Terrell351
06-13-2021 01:13 PM
Azrael91966669
DIY PROM
25
06-20-2017 04:04 AM
lakeffect2
08-23-2015 08:44 AM
mdtoren
08-16-2015 05:45 PM
Quick Reply: Mini Ram with Accel 1000 CFM Throttle Body?
