Where to get HOOD struts for fiberglass hoods?
Old 03-19-2009, 02:15 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
I need some hood struts for my fiberglass hood, and have been told not to use the stock ones because they compress too hard and will risk cracking the hood when shutting. i have seen them somewhere for sale before but can't remember. Does anyone know???? or are you with fiberglass just using one shock?????HELP!
Old 03-19-2009, 02:23 PM
RiggsLW81's Avatar
Car: 1987 IROC-Z Camaro
Engine: 350 (5.7L)
Transmission: 700R4 (Auto)
Re: Where to get HOOD struts for fiberglass hoods?
im in the same boat as you...have a fiberglass hood and was told not to use stock hood struts...i would like to know as well...
i was told that if you can find a very used/beaten up pair that doesnt work all the way (on a stock hood) it would be better since the fiberglass hood doesnt have the weight the stock one does.. however, cant find any beat-to-crap struts.
right now i use a painter's roller extension i got from home depot. it was 20 bucks... put a rubbger **** on the end of it and it compresses on itself like a baton. i stick it in their and rest it by the battery tray when i need to get under the hood.
if you get a real answer on fiberglass hood struts let me know.
Old 03-19-2009, 02:31 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
i am interested myself now since i read this i will be taking my stock ones out.
Old 03-19-2009, 05:15 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Been discussed here by me before.Heres what I found.
method 1:find a used set that can't hold up a stock hood.
method 2:go to the local auto parts store and buy the ones for 82-84 z28(they had factory fiberglass hoods)
I went with method 1 on my black GTA
Old 03-19-2009, 05:27 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
method 2 works perfectly....i got mine at o'reileys
Old 03-19-2009, 09:35 PM
85camarocrazee's Avatar
Car: 86 IROC
Engine: MAS Crate 350
Transmission: 97 T-56
Axle/Gears: 97 rear 3.43's posi
Im using a set of old worn out ones i kept for no reason when I bought my new ones for the stock hood. Sold the hood sold the new shocks. Surprising how cheap my fiberglass hood ended up being after selling all that GOOD crap lol!
Old 03-20-2009, 10:11 AM
Car: 87 iroc
Engine: 410 sbc
i was told also to use the 82-84 set also. just didn't really know who sells them and do you trust a low parts group to have the correct struts? maybe i am overthinking it?????
funkdubie- how are yours working????? doe they hold the hood up well and not be a pain to shut??
Old 03-20-2009, 10:26 AM
huffediroc's Avatar
Car: 87 iroc
Engine: 350 with weiand 144
Transmission: tremec TKO 600,mcleod street twin
Axle/Gears: strange s60
Any ones will work just take out the shocks and add a support stick to hold it open.
Old 03-20-2009, 10:29 AM
Former Sponsor
1Aauto's Avatar
Does anyone make a metal bracket for you guys that the stock strut would adapt to,taking some of the pressure off of the fiberglass ?
Old 03-20-2009, 11:13 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Hey what about the hatch???
Ones for the hatch are to strong for my fiberglass notch back.
THey sell 2 kinds, with and without wing.
Both are to strong, making the corners of the hatch lift when closed.
DId they ever sell ones special for the factory notchback?
Or did it weight just as much as a regular hatch?
see sig
Old 03-20-2009, 11:23 AM
Car: 87 iroc
Engine: 410 sbc
well i could just put a rod on it to hold it open and no struts. but i would rather have the struts, the hinges are on it now, just no struts.
Old 03-20-2009, 11:26 AM
Car: 87 iroc
Engine: 410 sbc
found a chrome prop rod here:
http://www.classicindustries.com/con...CategoryId=586
Old 03-20-2009, 11:27 AM
Car: 87 iroc
Engine: 410 sbc
and here is the fiberglass rod:
http://www.classicindustries.com/con...rchCatalogId=1
kind of expensive if you ask me.
Old 03-20-2009, 01:57 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally Posted by bigdavesiroc
Part Number: # 3965713
HOOD PROP ROD FOR FIBERGLASS HOODS
1967-69 Fiberglass Hood Prop: Hood prop required when installing a 1967-69 Yenko/Baldwin Motion fiberglass hood on you Camaro. Since hood springs are not recommended when using fiberglass hoods, this prop is essential for keeping your hood open while working in the engine compartment.
Old 03-22-2009, 12:42 AM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
call your local gm dealer and have them order the 82 -84 glass hood shocks...thats what i did....they work great....
Old 03-22-2009, 01:31 AM
RiggsLW81's Avatar
Engine: 350 (5.7L)
charged 350... how much were those u ordered?
Old 03-22-2009, 01:32 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
old ones that cant hold a steel hood worked for me
Old 03-23-2009, 05:06 PM
Charged350's Avatar
Car: 87 IROC Z28
i dont remember, but it was under 100 bux for both if i recal correctly...
Old 03-23-2009, 05:21 PM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Rockauto.com
AC Delco Part# 510951
STRUT,HOOD W/FIBERGLASS HOOD
$22.79
Old 05-08-2009, 11:01 PM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
i wonder is there a way to let some pressure out from the struts, like drill a small hole and some sort of plug to keep a little pressure? just a thought.
Old 05-09-2009, 01:52 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
bought mine at the dealership....for the early 82-84 fiberglass hoods....
Old 05-18-2009, 09:35 AM
two85z28s's Avatar
Car: 1985 Z28
I recently bought a pair of hood struts for my steel hood from a GM dealer.
It turns out they are actually StrongArm lift supports made by AVM Industries. The label on the strut is identical to the one you would get from Autozone or anywhere Mighty Lift or StrongArm struts are sold.
The StrongArm part # (4422) is actually on the part, in the GM packaging.
I often buy parts from the dealer if I don't know who makes good quality replacements, but if I can find out who makes the parts for GM, the price can be much less.
I priced the trunk struts and the discounted dealer price was 3 to 4 times Autozone's for the EXACT same part. (the hood struts aren't as much, so I don't feel too bad)
Here's AVM's web site.
http://www.avmind.com/
They have a lookup page that shows all of the part #s for different applications. (It takes a while to find) But is seems like they have parts for pretty much every 3rd gen hood & trunk.
Does anyone know who else supplies parts for GM?
It would be nice to know who makes certain parts so we can save money but still get the same quality.
Thanks.
Old 07-31-2015, 03:55 AM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Just to revive this old thread... RockAuto still has the struts for a fiberglass hood.
Hotrodboba400
12-10-2019 07:07 PM
mr z28
Exterior Parts for Sale
12-14-2015 05:14 PM
blackandblue02
09-10-2015 08:19 PM
Hotrodboba400
09-02-2015 07:28 PM
SlowAZ28
09-02-2015 05:19 AM
Quick Reply: Where to get HOOD struts for fiberglass hoods?
