HELP!!!! FIRE COMES OUT OF HEADER AREA
Old 03-18-2009, 06:12 PM
1990RSCAMARO's Avatar
i have a 1990 rs v-8 tbi camaro and the hooker super comp. headers i have in it get really hot and a little puff of FIRE comes out of the driver side header area.....any ideas why this happens? i just recently installed a new thermostat and water housing and filled it up with 50/50 coolent. only thing is i checked the oil level and im sure it needs alot of engine oil could this be why the engine and headers are getting hot and make fire come out of the header?
Old 03-18-2009, 06:15 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: HELP!!!! FIRE COMES OUT OF HEADER AREA
im pretty sure a bit of fire is common for open headers, ive seen it a few times anyway
Old 03-18-2009, 06:21 PM
jg04222's Avatar
Car: '82 Z-28
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
the engine being low on oil could attribute to it running hot. as far as the fire coming out of open headers, it's not abnormal, especially if your running a bit rich...it's usually just some unburned fuel that accumulates in the pipes lighting off.
Old 03-19-2009, 07:41 PM
thanks guys thats a relief but im not sure if my headers are "open" headers i have hooker super comp headers on my 1990 camaro are those "open" headers?
Old 03-19-2009, 07:44 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
do you have any exhaust on the car? or do you only have headers with no exhaust? just headers is open headers. do you mean the fire is coming from between the head/headers? or from the collector on the headers?
Old 03-20-2009, 05:50 PM
i have a exhaust i have flowmaster pipes with a hooker super comp. "box" at the end.im not sure where the collector is on headers but it seems to come from where the header and engine meet,the headers in the back of the engine on th driver side,its not roaring flames but a puff of fire that happens real quick and headers are getting REALLY HOT faster then normal..thanks man
Old 03-20-2009, 06:04 PM
50bmgshooter's Avatar
time for new header gaskets
Old 03-21-2009, 04:40 PM
thanks are they expensive?
Old 03-21-2009, 05:06 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
no they arent expensive just a pain AZ will have them
but you seem to have a symptom there not the problem you should check your timing make sure it is where it is supposed to be... retarded timing will lead to increased exhaust temps a decreased engine hp
Old 03-22-2009, 03:45 PM
thanks....
1992 Trans Am
05-10-2023 07:19 PM
TheExaminer
08-26-2015 04:59 PM
Dialed_In
08-20-2015 01:45 PM
mdtoren
08-16-2015 05:45 PM
Quick Reply: HELP!!!! FIRE COMES OUT OF HEADER AREA
