power to radio but wont turn on
Old 03-11-2009, 06:47 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i got a radio #vrcd400-sdu i think its a dual unit, im getting power to the ignition switch, but im getting no radio functions. i tried reseting it and everything, didnt work. is my radio fudged, or am i missing something?
Old 03-11-2009, 08:06 PM
87SnowFlake's Avatar
Car: 87 IROC-Z
Engine: jasper 350
Transmission: 700R-4
Axle/Gears: 2.73 posi
Re: power to radio but wont turn on
take the radio out and check your connections
Old 03-11-2009, 08:09 PM
i thought bout that but it worked before and now it dont
Old 03-11-2009, 08:29 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
if you have power to it only other thing to check is the ground. Make sure you have a good ground and power. If it doesnt turn on then check the fuse on the back of it and in the fuse box. If still wont turn on the radio took a crap. Good luck man.
Old 03-13-2009, 05:48 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
I would take the radio back out and twist the red a yellow wires together(ignition and constant) and hook it up to the battery to see if it comes on. If it dosent, then it crapped out.
BRoss99
12-07-2020 06:50 PM
Vintageracer
01-10-2020 05:33 PM
OLDYELLR
Car Audio
09-30-2015 07:10 PM
ZsTransAm
08-11-2015 07:30 PM
Quick Reply: power to radio but wont turn on
