carb on a 3.1L
Old 03-07-2009, 10:08 AM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
carb on a 3.1L
I was wandering if anyone has tried machining the top out of the intake manifold and putting a carb on it. it seems like it would work, but i don't know. I was thinking you could just unplug all the injectors and re-route the the fuel line to the carb. the only thing it should do wrong is possibly just throw a ckeck engine light. will that alter the ignition curve? any suggestions?
Old 03-07-2009, 10:24 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: carb on a 3.1L
You could just buy the carb intake from Edelbrock
Old 03-07-2009, 10:27 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Re: carb on a 3.1L
woah!! i didn't know that they made that for a v6! will it fit my 3.1L? do you know if it does away with all the FI stuff?
Old 03-07-2009, 10:31 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Re: carb on a 3.1L
btw, i saw that it only fits 82' to 85'. ive got a 92'. do you think it will still work?
Old 03-07-2009, 04:41 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: carb on a 3.1L
82-85 is just the carbed version of the 2.8, those years all the 2.8s came stock with a carb set up. getting one of those out of an s10 would be pretty easy. I would suggest a vacuum advance distributer to go with it. you can get those off of a carb 2.8 also. basically just get a carbed stock top end from a camaro or s10.
Old 03-09-2009, 11:06 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Re: carb on a 3.1L
will all this fit my 3.1L?
Old 03-09-2009, 02:18 PM
wes2008's Avatar
Car: 1992 Rs camaro
Engine: 3.1l
Transmission: 700-4
Re: carb on a 3.1L
if you have a 700r4 with a lock up converter you may need this
TCI 2004R/700R4 Lock-Up Wiring Kits
Torque Converter Lockup Kit, Wiring Kit, Vacuum Switch, GM, 700R4, Kit
http://store.summitracing.com/egnsea...4294839078+115
should be at top.
Old 03-09-2009, 06:21 PM
grimmcs's Avatar
Car: 91 Camaro
Re: carb on a 3.1L
yes it will. but its not as easy as just hooking it up and going...there are other things you need to do/change to get it to work right. Ive not really looked into the carb swap so I don't know much about it...do a search, there are a couple semi-recent threads about this.
Maybe more people will chime in and help you out.
Old 03-10-2009, 10:28 AM
8urv8's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Re: carb on a 3.1L
ok kool. about the lockup kit. i have the stock trans. in my car and i have a TCI 3200 stall converter. it looks like that kit has a wiring harness. i thought that GM didn't start the electronic hook-ups until 93'? I think the only one mine has is the reverse light switch. idk. and do ya'll think that if i leave the ecu in there to control the ignition, that the (possible) trouble codes will affect the ign. timing?
Old 04-08-2011, 06:28 PM
Ex Machina's Avatar
Car: 86Z28-H, 88Z28-E, 84fbird 6, 90rs 6
Engine: 305 4bbl, 305 Tbi, 2.8 2bbl, 3.1 FI
Re: carb on a 3.1L
Quick question, if you swap the 3.1 along with the matching transmission would you still have to buy the lock up kit?
Old 04-08-2011, 07:49 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: carb on a 3.1L
This is a really old thread. Are you going to be using a carb or fuel injection? If fuel injection both 2.8's and 3.1's with mpfi have a 700r4 and you do not need any lock up kit if it's carb'd then you would need the lock up kit for the 700r4.
Old 04-18-2011, 01:05 AM
Ex Machina's Avatar
Re: carb on a 3.1L
Thnx for the answer! didn't think i would get a response. I'm gonna stick with the stock carb for the time being. my car came stock with a 700r4, I had heard that the early 700r4s' had alot of problems that would later be resolved in the newer models and thought i could upgrade instead of rebuilding the old one. didn't know if i had to get the lock-up kit 4 it.
RedLeader289
05-28-2019 01:47 PM
HoosierinWA
10-07-2015 10:15 AM
IROC ZELLER
09-29-2015 03:00 PM
efiguy
09-27-2015 01:30 PM
Quick Reply: carb on a 3.1L
