87-89 350 TPI ESC Module
Old 03-06-2009, 01:19 AM
Dany89's Avatar
what is the function of the 87-89 350 TPI ESC Module ??? what does it do???
Old 03-06-2009, 05:36 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: 87-89 350 TPI ESC Module
In my chiltons manual, it says that the ESC system(electronic spark control) is used in conjuction with the EST system(electronic spark timing) to reduce spark knock by retarding the ignition timing. A knock sensor, which is installed in the cylinder block, sends a signal to the ESC module and then in turn to the ECM, which then adjusts timing accordingly.
Old 03-09-2009, 04:18 PM
Dany89's Avatar
So if ECM would happen to not work what will happen???
Old 03-10-2009, 06:32 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If the ECM doesn't work, the engine won't run.
If you meant to ask what would happen if the ESC didn't work, you'd probably get knock from too much timing advance. Or false knock on the other hand, which would actually rob your engine of power randomly. It's hard to say which one.
Hope this helps.
Lou
Old 05-29-2010, 07:57 AM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
hey guys i have a carb engine, so do i need the ECM? im cleaning up my wiring harness and want to get rid if it, do you have any suggestions? thanks.
Old 05-29-2010, 08:02 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by camarozz383
hey guys i have a carb engine, so do i need the ECM? .
No
Just keep the wiring to the gauge senders in engine .All you need is power to the coil and some way of making the fan and fuel pump run without the computer
Old 05-29-2010, 08:15 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
do you know what each wire does?
Old 05-29-2010, 08:17 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
theres a pink with black stripe, brown, black and white wire with a connector.
Old 05-29-2010, 08:24 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
Old 02-29-2020, 06:43 PM
David Wise's Avatar
I think that I have the same problem. Fitted a new distributor but it won't spark. Was thinking that it might be the ESC module.
Old 02-29-2020, 06:48 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The esc module is for knock retard and will not kill spark.
first verify you have power to the ecm, check pu coil output. If that’s fine it could be a faulty icm. Please start a new thread this ones dead.
David Wise (02-29-2020)
theurge
08-21-2015 12:46 PM
Out-Cast
08-17-2015 10:57 AM
Jlanz55
08-17-2015 07:15 AM
bamaboy0323
08-15-2015 07:20 AM
wruiz
08-13-2015 09:07 PM
Quick Reply: 87-89 350 TPI ESC Module
