Pick-up coil removal
Old 03-03-2009, 05:07 PM
1987-iroc-z383's Avatar
Car: 1987 chevrolet camaro Iroc-z
Engine: 383 tpi
Transmission: built 700r4
Axle/Gears: posi 3:45
Ive been messing around with my car as it wont start anymore. No spark, replaced the dying fuel pump,filter, coil, module. If i take it the distributor apart and remove all the connections and replace them and put it all back together and try starting it will start then die instantly. I am finally going to try replace the pick-up coil in the distributor.... My question is, How do I go about removing the old one??? 87 Iroc, Hei remote coil system
Old 03-03-2009, 05:20 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Re: Pick-up coil removal
did it last year some time....you have to disassemble the distributor(take off coil, cap, rotor, ign. module etc.). Its easier with two people ecpecially when it comes to hammering out the little pin at the bottom of the distributor so the shaft can come apart to access the pick up coil....not very hard, just remember your steps during the process so you can put it back together properly.
Old 03-03-2009, 05:28 PM
Engine: 383 tpi
Up until removing the distributor i have down very well lol, just once the module and rotor are off, do you just pry at the cylindrical ring thing or is there a clamp?
Old 03-04-2009, 04:50 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
There's a pin at the bottom of the dizzy shaft. You have to drive it out, remove the gear, and then the whole thing will come apart giving you free access to the pickup coil.
Old 03-04-2009, 07:19 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
throwing parts at cars
did you check the resistance of the pickup coil first
man can I have a loan with all that wasted money you are throwing around
I know, the car is old and you want to replace everything?
Old 03-04-2009, 07:37 AM
snardos's Avatar
Car: 1992 camaro z28
Axle/Gears: 2.73:1
Be careful when removing the shaft from the case. It can be a tight fit and might want to get stuck. I have heard of people breaking the case by getting it stuck and trying to tap it out with a hammer. Make sure the inside stays lubricated while taking it apart.
Old 03-05-2009, 06:22 AM
jamon8's Avatar
Engine: 350 tpi
check the resistance in the two pronged plug that comes off the pickup and plugs into the module
500-1500 ohms=good
Old 03-26-2009, 11:08 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
BUMPED!!!!
I am having a similar little issue, where the car only misfires when the EST bypass connector is connected...
I checked the resistance of the new one still in the box and it is at 758Ohms while the old one on the car is at 816Ohms... is this enough of a difference to cause this issue. Also when you press out the roll pin on the drive gear, can you reuse it?? i kind of want to do this tonight and everyone is closed....
Old 03-27-2009, 04:18 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
It should be fine and yes you can reuse the pin.
Old 03-27-2009, 10:28 AM
boldguy's Avatar
Car: 1992 Z28
I dont know how to test it under load though. To my knowledge When the EST bypass connector is disconnected, there is a smaller load on the pickup coil??? Does it sound like it could be the culprit here?? Ill replace the pickup coil tomorrow and see what happens.
Old 03-27-2009, 10:49 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Save your self some headaches, buy a reman dissy and just drop it in. it will come with all new parts and a warranty.
Old 03-27-2009, 11:40 AM
boldguy's Avatar
Car: 1992 Z28
This one is Reman with a lifetime warranty but it will take some time for it to come in. I think i will return the parts and just warranty this one out for a new one...
Old 12-10-2022, 02:36 PM
SlickVick's Avatar
Car: 92 Camaro RS
Engine: 3.1L V6, stock
500-1500 ohms=good
Sorry to post on such an old thread but y'all were talking about it. I got good ohm between the two leads but have a service Manuel says test between lead and ground on dist plate should be infinite, but I get nothing from this test. Does that mean my pickup coil is toast.
Old 12-10-2022, 04:30 PM
OrangeBird's Avatar
Car: 1989 Firebird
Infinite means nothing, so since in your case there is no connection to ground, your pickup coil has passed that test......
Old 12-12-2022, 04:20 PM
SlickVick's Avatar
Car: 92 Camaro RS
Aw heck I'm an idiot, I was thinking I was supposed to get the beep for continuity. Book said infinite so I thought a beep or at least some reading should show, thinking backwards as usual, thanks!!
morrow
01-13-2024 12:29 PM
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
TheExaminer
09-06-2015 11:40 PM
RyanJB
09-02-2015 01:27 PM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
Quick Reply: Pick-up coil removal
