How do you know if your rear end is going bad?
Old 05-25-2001, 11:43 AM
KeithO's Avatar
I have an 88 IROC with the L98. I have the 2.77 rear end gear (RPO GH3) with posi-traction (RPO G80).
When going around corners under moderate acceleration, there is a subtle oscillation (about 0.5 second frequency) that feels like the power is being transmitted back-n-forth between the two rear wheels. This is a relatively new behavior.
Is my posi unit going bad? This is the first car that I have had with a posi unit so I don't have any experience spotting trouble or working with posi units.
Thanks.
Old 05-25-2001, 11:55 AM
82camaro's Avatar
Car: 82 camaro SC
Before you assume it's bad, change the fluid and install the posi additive.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old 05-25-2001, 12:53 PM
KeithO's Avatar
Well, I had a trusted mechanic do that about 2,000 miles ago. He said everything looked good. Even so, I had him change the reatr end gear fluids for me. Since that time, I've autocrossed the car in 5 events and I am wondering if I haven't pushed it beyond it's capability...
Old 05-26-2001, 08:17 AM
KeithO's Avatar
Anyone else have any ideas?
Old 05-26-2001, 10:48 AM
Tom Keliher's Avatar
Try a burnout. Look at the asphalt tatoo you leave. It should be equal from both tires. If not, that is a good indication the posi is bad.
Old 05-26-2001, 12:53 PM
KeithO's Avatar
I do get two black marks on burnouts. However, I still feel this oscillation. Is this normal and I'm just being oversensitive to it?
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
Jlanz55
08-17-2015 07:15 AM
1992 Trans Am
08-08-2015 08:16 PM
3rdgenparts
08-06-2015 09:03 AM
Quick Reply: How do you know if your rear end is going bad?
