L69 83-86 "HO" FACTORY Intake Manifold
Old 01-14-2009, 10:47 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Can anyone tell me ( FOR SURE ) which one of these Intake Manifold styles was FACTORY install on thier all original 83-86 L69 "HO" motor ??
These are all 82-86 Aluminum intakes with the same part number. The intake with raised "ribs' on ports 2-3-5-8 is about 1 pound heavier than the other 2. ( I removed ALL the fittings before wieghig each. ) The second style has a "checkboard" stamped into the front and back and the third design is plain.
Thanx in advance !
Old 01-14-2009, 04:50 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: L69 83-86 "HO" FACTORY Intake Manifold
Well, from what I'm seeing...all three have the same cast number, so if one is an L69 manifold (which I doubt the intake is different between it and a standard 305) all three are.
Doing some google searches on the casting number, looks like that intake was used on alot of 305 and 350 engines all the way up to '86 so I again doubt they used a different intake. Mostly I believe the L69 had different heads, and cam.
Old 01-14-2009, 04:57 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
LG4 and L69 used the same intake. I think the different styles is more down to production date. My 8/84 built '84 Trans Am has the checkerboard intake.
Old 01-14-2009, 05:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
The cam is different, the heads are the same.
Old 01-14-2009, 08:06 PM
Klortho's Avatar
Car: 1987 GTA
Ahh ok, I thought I remembered reading somewhere that the heads on the L69 was the same as on the LU5 crossfire engine and the LG4 heads were different.
Old 01-14-2009, 09:55 PM
Dens71TA's Avatar
'82-86 LG4, LU5, and L69 all use the same "416" heads. The reason for different compression ratios is that '82-84 LG4s used dished pistons to yield 8.6:1 compression ratio instead of 9.5:1 with the flat tops the LU5, L69, and later LG4s had.
Old 01-15-2009, 12:20 PM
John in RI's Avatar
While the heads were (arguably) the same, the HO motor did receive the larger 1.84 / 1.50 valves compared to the LG4's smaller 1.76 / 1.46 valves (this fact is probably what causes people to argue that the heads were 'different'. It is not that the heads were different, it is the valve sizes that were different!).
Source: http://www.goingfaster.com/spo/praisetbi.html
Old 01-15-2009, 03:11 PM
pontiacguy1's Avatar
The 1984 L69 engines received bigger valves in the common iron heads, the cam from the 1982 Cross Fire 350 Corvette, flat top pistons, larger H.O. exhaust manifold castings, and the larger exhaust system all the way back. That was what accounted for the 30 HP increase over the regular 305.
The intakes on the L69 was just the same as the ones used on ALL 305 engines. I would say that your intakes were cast during different runs or years, which would account for the difference in appearance. As far as performance goes, the Stock aluminum intake on those cars wasn't too bad and it actually flowed as well or better than some of the lower end 'performance' replacement intakes.
My 1984 15th anniversary T/As have the intake that looks like the lower one in the last picture, from what I remember. I know they don't have all those ribs on there. I will have to go see if they have those 'checkerboards' near the rear.
Old 06-11-2009, 12:38 PM
iroc_zz's Avatar
Car: 1985 IROC-Z
Engine: 305 H.O.
Transmission: 5 Speed
Axle/Gears: 7.5" 10 bolt, 4.10, torsen posi
I can pull the intake from my 85' L69 out of storage and get a pic if your still wanting to know
Old 06-12-2009, 08:06 AM
daveb123's Avatar
Car: 82 Z28
Transmission: BW T-10
My 85 has the 2nd style- production 12/84.
Old 06-18-2009, 10:10 PM
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
My car has the second intake manifold (checkerboard pattern). It was built in mid-'84 (July, I think).
Old 06-19-2009, 07:19 AM
iroc_zz's Avatar
Car: 1985 IROC-Z
Engine: 305 H.O.
None of the above
This is off my 85' L69 Iroc
Old 06-23-2009, 11:02 PM
John in RI's Avatar
Interesting ! The same casting number ( again) yet a combination of the "checkerboard" and the ""ribbed" styles !
Thanx for the pic !
Old 06-24-2009, 07:55 AM
iroc_zz's Avatar
Car: 1985 IROC-Z
Engine: 305 H.O.
It would be intresting to find out how many other variations their are.
I wonder if the numbers cast below the "GM CFM" (15, 19, 38, and 45) mean anything?
Old 07-01-2009, 10:22 AM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
I've had 2 '84 l69 cars and both had the middle checkerboard style intake. My current '83 LG4 also has that same intake.
transaero
08-31-2015 01:14 AM
Bubbajones_ya
08-28-2015 02:17 AM
theurge
08-21-2015 12:46 PM
Jake_92RS
08-11-2015 10:39 AM
Quick Reply: L69 83-86 "HO" FACTORY Intake Manifold
