What model/year GM's had 416 and 601 casting heads?
Old 01-08-2009, 06:32 AM
quick57's Avatar
What model/year GM's had 416 and 601 casting heads? I'll be heading to the local Pull Apart Friday and want to know which vehicles to source for those castings. What are the valve cover bolt patterns standard or centered?
Old 01-08-2009, 08:36 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The valve cover bolt pattern was perimeter for both.
Not sure where you live, but I have a pair of 416's I'd let you have for the cost of shipping.
Old 01-08-2009, 11:43 AM
quick57's Avatar
Re: What model/year GM's had 416 and 601 casting heads?
I have it narrowed down to vehicles from 80-85'. Not sure if trucks or cars have em' or both.
Old 01-08-2009, 06:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
trucks/vans got the 601s while cars (caprice, cutlass, camaro, etc) got the 416s.
Common as dirt. If you're near Colorado take up 57. you wouldn't even have to blow an afternoon unbolting them in the snow
Old 01-08-2009, 09:07 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
My 86 LB9 has 416 castings, so i assume they were around till the 87 change
Old 01-08-2009, 09:13 PM
Fast355's Avatar
Car: 1983 G20 Chevy
416 heads ran from like 80-86 and were replaced by the 081 heads for the 1987 model year on ALL LG4 and TPI applications.
The 601 heads ran from 80-86 and were replaced by the 187 heads for the 1987 model year. The engine code changed from LE9 to L03 in trucks.
Old 01-13-2009, 01:15 PM
quick57's Avatar
57kid pm sent
I'm building a severely budgeted 350. Cleaned and ready 350 std. bore. want to use 305 heads with a fairly high duration (280-290) lunati bracket master cam good to 5500 rpm. and a small runner single plane like the Weiand exelerator or old tm1 torker. Would I be better off with a dual plane? The car will see 30/70 split street/strip duty.
norcalz28
Northern California
26
12-07-2016 12:49 PM
92projectcamaro
01-18-2016 08:00 AM
Hotrodboba400
09-02-2015 07:28 PM
z28guy134
09-01-2015 11:50 PM
Quick Reply: What model/year GM's had 416 and 601 casting heads?
