INFO ASAP:what year 700r4 do i have
Old 04-09-2001, 10:40 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i going to buy a 700r4 from a guy for $200.how do i tell what year tranny it is?i want to know what year it is so i know if it's a 30 spline or a 27 spline.and also if it is a 700r4 and not a 200r4?
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation/
Old 04-09-2001, 07:59 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Look at the serial number stamped on the case right above the panrail. It will have something like "7YDM" stamped into it. That number is the year. The code listed above is a 1987. You could also pull the pan. If it has just the valvebody, then its '86 and prior. If it has the valvbody, and smaller Auxilary Valvbody w/ a metal tube going to the pump, then its '87 and later.
Oh yeah, and the difference between the 200 and 700, the 700 has a squarish pan, the 200 has "tombstone" shaped pan, w/ a large sump and a small sump. Its hard to explain, but if you see the 200, you will understand.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
[This message has been edited by GMTech (edited April 09, 2001).]
Old 04-09-2001, 10:07 PM
91banditt2's Avatar
Engine: 5.7 HSR
the code "7YDM" does the 7 indecate the year?
Old 04-10-2001, 05:55 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yeah, thats what I was getting at, sorry.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
--&gt;14.97 @ 94.9 MPH&lt;--
'97 Bonneville SSE
Old 04-10-2001, 07:36 AM
91banditt2's Avatar
Engine: 5.7 HSR
thanks GMtech
check out streetdawgracing.com
Old 04-10-2001, 07:40 AM
91banditt2's Avatar
Engine: 5.7 HSR
will the code be the same except for the year?1987=7YDM,1988=8YDM,1989=9YDM?
Old 04-10-2001, 09:43 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
No, the "YDM" was just an example. yours will probably be something like a "6FHM" or somthing. The first digit is the year, 6 = 1986, 1996, etc... ( you will know if is an '86 or '96, the '96 will be a 4L60-E).
The second usually is the same as the carline. For example, the "7YDM" will most likely be found on a 1987 "Y" body car (Corvette). If the tranny came out of an "F" body, it will have the year digit, and probably an "F" along w/ two other letters.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old 04-10-2001, 10:10 PM
91banditt2's Avatar
Engine: 5.7 HSR
thanks again
BlueIroc-Z
06-09-2019 03:22 AM
Reddeath210
10-06-2015 08:20 AM
Thornburg
08-25-2015 01:46 AM
g.l.mos
08-22-2015 12:02 AM
formula_novice
08-18-2015 08:48 PM
Quick Reply: INFO ASAP:what year 700r4 do i have
