Full engine gasket set for LT1
Old 12-31-2008, 03:32 PM
krisfnbs's Avatar
Where would I purchase this?....roughly how much does it cost? Is it just the upper end set and lower end set or is their more to it?
Old 12-31-2008, 04:27 PM
TexasLT1's Avatar
Car: '92 RS
Re: Full engine gasket set for LT1
http://store.summitracing.com/egnsea...115+4294889104
Old 12-31-2008, 04:45 PM
krisfnbs's Avatar
Looks great. Anywhere to get that cheaper?
Also what is the difference between the first one and second one at summit racing?
Old 12-31-2008, 05:16 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I don't know if I would go with either of those, I know that Fel Pro has an upper set and lower set. When I put mine back together, I just bought mine in pieces....ended up cheaper doing it that way...all Fel Pro
Old 12-31-2008, 07:42 PM
krisfnbs's Avatar
what did you end up paying for all of them?
Old 12-31-2008, 10:27 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Any parts store that stocks FelPro stuff could get you their set. Just ask for one for a '93-97 Camaro/TransAm if you are using aluminum heads, '95-96 Impala if using iron heads. Be careful if ordering the Impala set, as they were available with a Gen 1 (SBC TBI) and Gen II (LT1) 5.7L engine - make sure you get the right set.
midge54
12-27-2019 04:14 PM
Azrael91966669
DIY PROM
25
06-20-2017 04:04 AM
midge54
01-29-2017 07:00 PM
NinjaNife
08-23-2015 11:49 AM
bradleydeanuhl
08-12-2015 11:48 AM
Quick Reply: Full engine gasket set for LT1
