gauge lights not working
Old 12-17-2008, 11:31 PM
a1990camaro's Avatar
Car: 1990 RS tbi camaro
Engine: 5.0 tbi stock, hooker headers
any one know why my gauges are not working i replaced the fuse for the gauges and it still doesnt light up they used to work and now stopped working. is there a bulb behind the gauges that goes out? all my other lights work inside and out, exept the tail-light
Old 12-17-2008, 11:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Re: gauge lights not working
Check the headlight switch.
Old 12-20-2008, 01:15 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Apeiron is right - the dimmer control on the headlight switch is the first place to look. Make sure it is not in the "off" position before going any further with troubleshooting.
Old 12-21-2008, 12:21 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The lights in your dash are connected to your tail lights. If your dash lights dont work then you know your tail lights are out.
Old 12-22-2008, 11:28 PM
the **** is in the "on" position. and my dash lights are out,but all my back lights work except my tail light:my third brake light
Old 12-22-2008, 11:36 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
there is also a lighting module that may be bad. It's by the blinker/flasher breakers and buzzer speaker. if all else is good, this may be your issue.
TWON_3rdGEN (12-29-2019)
Old 12-23-2008, 06:39 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
This is an quote from another thread where I posted some pictures from the factory manual to show where the actual dimmer module is. Here is the whole thread that is titled "Dash lights not working".....
https://www.thirdgen.org/forums/elec...tml?highlight=
Originally Posted by ghettocruiser
Couple things it could be... One. Double check the fuses. Swap the one that the cig lighter is on... just to be sure. Its the same fuse as the dash lights if I remember correctly. Sometimes fuses can blow and they're hard to see.
Now...Im willing to bet its one of two issues. I didnt look back into your old problem very much. But Im thinking its either the switch, or the remote dimmer. Ide almost put my money on the remote dimmer. This little sucker is tucked away nicely on the passenger side of the steering column. Its very hard to get to, and almost impossible to see. Ill post the info that I have on it. I just helped someone else with it, so I even have some snap shots of the factory manual from GM showing the location. The picture is of the steering column brace....you can kinda get your hand up there. haha... its fun.
I think its silly for where they put it, especially since they seem to go bad frequently. Just a tip...you can get to the plug and un-hook it, and bring the wiring down to the new part to test it first before you try to remove/replace it.
That might help ya out some.
J.
J.
Ive never experienced this... They are on a completely different circuit, are they not? Ive had my "instr" fuse blow due to a dime stuck in my cig lighter...but my tail lights still worked fine.
J.
Last edited by ghettocruiser; 12-23-2008 at 06:42 AM. Reason: Automerged Doublepost
Old 12-23-2008, 05:54 PM
birdtojag's Avatar
That's the module I was talking about. Thanks for correcting my wording. I had that happen to me too. Hard to get at without taking some things out of your way, but possible.
Old 12-23-2008, 09:12 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
J.
J.
That's nice and all, but the Camaro's don't have the dimmer module.
Old 12-24-2008, 12:14 AM
any other ideas?
Old 12-24-2008, 02:06 PM
WSX123's Avatar
Car: 1988 Trans Am GTA
Check the bulbs there are bulbs in there, i actually just replaced a couple in mine, also had to rplace the bulbs where my a/c heater controls are both went bad try that u can pick them up at advance auto or napa
Old 12-25-2008, 02:46 AM
Guy In A 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
Like Apeiron said earlier, check the headlight switch. Probably just wearing out. . .
#26 in the picture. (from the Chevy 90' Camaro Service Manual)
As for your 3rd brake light, have you removed it and checked the bulbs? I wouldn't be suprised if all 5 of those lil' bulbs burned out. Mine were out when I bought my car. No one ever bothered to change them. . .
Old 12-25-2008, 03:20 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Check the 5 amp (orange) fuse. I know it sounds dumb but I blew it and thought the lights were on a different fuse and didnt even know it.
Old 12-25-2008, 02:05 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
You said you replaced the gages fuse, but was that the 10 amp "gages" fuse, or was it the 5 amp "inst lp"(instrument lamps) fuse? Changing the 10 amp fuse wouldn't have affected the lighting. So, yes, check that 5 amp fuse.
But if the "inst lp" fuse is ok, then also check the 20 amp "tail" fuse. Even tho the dash lights have their own circuit, that circuit is tied to the taillight circuit, and the headlight/dimmer switch controls them all. And, therein, lies the connection between the headlight/dimmer switch, the dash lights and the taillights. So if the "tail" fuse blows, the "inst lp" fuse can remain unaffected, yet you'll still have no dash lights.
If the "tail" fuse is bad, however, then replacing it will probably just lead to blowing the new fuse the instant you turn the lights on again, telling you there's, obviously, a short somewhere that you'll have to track down.
Old 12-26-2008, 08:36 PM
i changed the 10amp "gauges" fuse and the 20amp "tail" fuses everything electric works exept my gauge lights.also i have no fuse in the "radio" slot if that matters.also i have taken out the fuse for the trunk latch motor because if that use is in the motor doesnt shut up. thnx firebird guy
sailtexas186548
Exterior Parts for Sale
02-29-2016 08:40 AM
Reddeath210
10-06-2015 08:20 AM
Wade787b
09-29-2015 01:15 PM
Omega
08-10-2015 12:46 PM
Quick Reply: gauge lights not working
