trying to jack up engine to change oil pan "HELP"
Old 12-09-2008, 11:30 AM
dexint's Avatar
im trying to jack up the engine to change the oil pan gasket and when i try and jack it up the whole car raises but when i pry on the motor mounts from on top of the car the engine moves any ideas is it just stuck on the motor mount edge or somthing i cant figure it out or is it the tranny crossmember holding the whole car up
Old 12-09-2008, 12:12 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: trying to jack up engine to change oil pan "HELP"
if you have the motor mounts disconnected then you need to jack from the harmonc balancer
also you should take the dissy cap off at least
at most you must remove the dissy
get some 3inch long 2x4s and when the motor is high enough put the wood inbetween the motor mounts and the clamshells
Old 12-09-2008, 12:24 PM
dexint's Avatar
i tried to lift at the oil pan and balancer but it just lifts the car but i know its looses cause i can pry the mounts and the engine moves out of them
Old 12-09-2008, 02:54 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Lift a little bit, pry. Lift a little more, pry. After a couple of tries, it'll come up.
Old 12-09-2008, 05:25 PM
dexint's Avatar
got it thanks guys
B_Dubya
08-26-2015 05:09 PM
Navy8125
08-21-2015 09:32 AM
MY87LT
08-17-2015 08:43 AM
matthew911
08-12-2015 09:38 AM
gwade12
08-08-2015 08:17 AM
Quick Reply: trying to jack up engine to change oil pan "HELP"
