6.0L Vortec Lq4
Old 11-14-2008, 11:45 AM
10secondhopeful's Avatar
Car: '84 Z28/'82 Z28/'02 C5Z
Engine: 350 cam, boltons/350/cam boltons
Transmission: 700r4/700r4/M6
Axle/Gears: 3.73/3.43/3.43
6.0L Vortec Lq4
I might be able to get a LQ4 6.0L Vortec motor out of a chevy truck 1999-2004. will it bolt up to a 1991 700r4?
Will it be worth the hassle of swapping the motors and getting all the computerized **** hooked up? (my motor right now is carburated). Or should i just jack the heads off of them?
stock hp rating is 300HP with like 360 ft lbs.
if i got the heads, the required edelbrock RPM intake manifold, and headers, i think i could push 320HP and 350TQ or so. what do you guys think?
Old 11-14-2008, 01:02 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The LQ4 is an LSx Gen III type engine. The heads won't fit a Gen I block. Why they kept using the Vortec name when the engine was completely redesigned is beyond me.
If you do such a swap, carb is, in my personal opinion, a complete bastardization of the engine. But, that's just my opinion (backed up by the fact that it would cost more to make it run with a carb than it would with proper FI).
Moving to the proper forum.
Oh, and read the LSx swap sticky in the top section of this forum.
Old 11-14-2008, 01:22 PM
Re: 6.0L Vortec Lq4
okay thanks a million
Old 11-14-2008, 01:51 PM
On Probation
Atilla the Fun's Avatar
Car: seeking '90.5-'92 'bird hardtop
Engine: several
Transmission: none
Axle/Gears: none
Re: 6.0L Vortec Lq4
Try to get an '01-up engine. There were several hard-to-see improvements.
Old 11-14-2008, 05:42 PM
bygblok's Avatar
Re: 6.0L Vortec Lq4
I know of a 6.0 car here in Pensacola that has a stock bottom end, a decent cam with some mild head work that runs 6.50's on a mild tune with a 100 shot of spray. I do believe that's DEEP in the 10 second range you're seeking. His runs through a th350 and a 9" as well. Mine is right behind him now too. The LS is going in this week. And as far as a carb being a "bastardization", TJ's car knocks down 13mpg or so with a 4.33 gear on drag radials, drives to and from the track and is a great street car. I can only HOPE my hotrod is a good as his. Nothing wrong with a carbed LSx motor at all.
Old 11-15-2008, 07:41 PM
Hog
Hog's Avatar
Re: 6.0L Vortec Lq4
Get an 01+ LQ4 as it will have the aluminum heads.
The block will fit to your trans, but you need to run a specific flexplate, crank spacer and longer bolts.
Check out this link for parts.
http://www.pacificp.com/forum/viewtopic.php?t=7252
That info was for a 4l60e/65/e/70e, but will also work for your 700r4.
epace
Hog
69GTOby
04-18-2016 02:34 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
Quzyle
DIY PROM
10-15-2015 03:35 PM
3GZJerry
LSX and LTX Parts
10-14-2015 05:17 PM
monte87cortez
09-26-2015 08:10 PM
Quick Reply: 6.0L Vortec Lq4
