TBI to carb conversion?
Old 11-08-2008, 10:01 PM
Cdeez's Avatar
Car: Too many to list...
I would like to know about converting from TBI to carb. Other than intake, carb, and dizzy, what hard parts would be required and what is the general procedure for this swap?
Truck: 1990 Chevy. 350 TBI - 700-R4
The truck has a slew of bolt ons, + cam (crane2030) and ported heads, Bored .060 .
Please share with me anything you would be kind enough to share
Old 11-09-2008, 11:54 AM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Re: TBI to carb conversion?
You will also need a return style fuel pressure regulator or a fuel pump designed for a carb.
Old 11-09-2008, 02:20 PM
buymytransam's Avatar
Car: 2005 Audi A4 Avant
Engine: 1.8T
There is an excellent technical article on how to perform this conversion. It's one of the top articles on the list, definitely check it out. I'm also in the process of converting from TBI to carb.
Old 11-10-2008, 07:57 PM
mvd72786's Avatar
Car: 1989 Camaro IROC-Z
Engine: 305ci 5.0L (TBI to carb)
Transmission: manual
got the fuel injectors off... after i took this pic i cleaned off that manifold as best i could, as you can see its pretty nasty, stuff all over it. anyways, after that i removed the manifold, and when i took my foot off the front end, the car shifted, and part of an acorn fell from somewhere, directly into the #3 port. i couldn't believe it, a hole in one. anyways, i rigged up a piece of 3/4" plastic tube to the end of a vacuum cleaner and was able to get it out of there, and then i vacuumed the other ports just to make sure nothing fell in there... they were clean. as soon as i get the new manifold i will post some more pics.
Old 11-10-2008, 08:00 PM
mvd72786's Avatar
also... i'm not totally familiar with all of the un-necessary items (when switching to carbed), any chance anyone could point out in this picture what i don't need and can remove? thank you very much, everyone here has been extremely helpful so far.
Old 10-27-2011, 12:30 AM
glen milley's Avatar
Can you tell me where I can find that article I am new to this site. GlenM.
Old 10-27-2011, 01:15 PM
VORTECCADDY's Avatar
Engine: 383 Superchared
Transmission: 700r4 built
Search function works wonders.
Old 10-28-2011, 11:23 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
It's linked in the "welcome to the carburetor forum" sticky in the top section of this forum.
It can also be found by going to the thirdgen.org homepage and clicking on the tech articles link on the left side of the page.
Old 06-09-2014, 10:54 AM
onemanarmy41's Avatar
Car: 88 k15000
Transmission: th400 (m80) 4x4
Axle/Gears: original
the biggest issue I notice is the 700r tranny how to control it
look at my conversion and if any questions reply
Old 06-09-2014, 12:31 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Why do you keep bumping so many old threads? Let them die
Old 06-09-2014, 04:37 PM
Car: 88 k15000
my apology didn't realized the date was so old
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
db057
04-28-2019 07:45 AM
383cam
09-09-2015 06:01 AM
willyjoejr
09-03-2015 09:26 AM
GeneralIesrussi
09-03-2015 03:23 AM
Quick Reply: TBI to carb conversion?
