Best Cam for a 350 TPI
Old 11-04-2008, 08:51 PM
camaro350tpi's Avatar
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
Hi ! just want to know what will be the best cam to but in my engine with the stock intake or the best cam/intake combinetion for the l98 tpi ! thanks u all !
Old 11-04-2008, 09:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Re: Best Cam for a 350 TPI
stock heads? Are you willing to have some work done to the heads for abit more cam lift?
stock heads are generally only good to about .470 lift or so before you have problems. You can shim them up to handle .510 lift or so. I'd recommend it for some cams.
but for true stock heads with new valve springs, crane powermax 2032 cam is a nice cam. it works well with stock intake/heads.
if you have better intake (siamesed TPI/HSR/miniram/superram) and some port work done, you can go alittle more duration like a 218/224 or such.
Old 11-04-2008, 09:50 PM
yes on the stocks heads , can i put 1.6 roller rocker with the 2032 cam ?
Old 11-04-2008, 09:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
if i recall right, the 2032 cam is .452/.465 with 1.5 rockers, so no dont run 1.6's unless you plan on adding shims/offset valve locks to get your lift capacity up. 1.6 rockers will net .482/.496 so you will need to shim up the springs to allow that to happen. not a bad idea and not hard to do since you need to replace your springs anyway, just buy offset valve locks, +.050" offset is needed, then get .045 worth of shims since most shims only come in .015, .030, .060 increments. Get a pack of .015 and .030 to lift up the spring assembly. that will allow you to run darn near .520" lift but i'd keep it down to .500-.510 for clearance safety purposes
Old 11-04-2008, 10:50 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
get a crane 2032 cam.. its in my 350 tpi it has a lumpy idle but i have alot of supporting mods.... this cam can go into a competely stock 350 tpi with no problems.. but i suggest replacing the springs that match with this cam.... look at my videos and you will see my mods
http://www.youtube.com/watch?v=YmAOjTj03yU
http://www.youtube.com/watch?v=Yja12...eature=related
Ken56 (11-08-2021)
Old 11-05-2008, 01:56 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
It's my opinion that its not worth it to do the work to put a bigger cam in our cars if you're keeping the stock heads. For one, the valve springs on those heads are 20 years old and worn out. Also the valve guide seals will need to be replaced as well so you dont get the puff of smoke on startup. The valves themselves have probably seen better days, too, and arent making a good seal in the seats as well as they used to.
But if you're dead set on it, make sure you at least replace the valve springs and the valve stem seals. I recommend Manley 22410-16 springs and 23652-16 retainers, along with 13091-16 valve locks. That'll allow you to run up to .550" lift camshafts, so you could run the 2032 cam with 1.6 rockers. But you will also have to change to screw-in studs to run that much lift, Manley part# 42106-16. The valve stem seals you'll have to get elsewhere, Manley doesnt make them for the stock heads.
And since you have to remove the intake manifold to change the cam, you might as well replace it as well with a TPI intake manifold from Edelbrock. (they make all the TPI manifolds now and have the best price)
Old 11-05-2008, 02:13 AM
jakemk8706's Avatar
Car: 1991 Z28 Camaro
Transmission: WC-T5
is there some type of formula you are using to determine the lift when you factor in rocker arm ratio's???
Old 11-05-2008, 02:35 AM
Kevin91Z's Avatar
Yes, take the stated lift with 1.5 rockers, and divide by 1.5. That will give you the lobe lift of the camshaft. Now multiply that number by 1.6 and that will give you the new lift with 1.6 rockers.
Old 11-05-2008, 11:37 AM
92 Z-28 Camaro's Avatar
Car: 1992 Z-28
Transmission: auto
Hi Folks
with my mods the LT-4 Hot cam with 1.6 roller rocker works great - drivable and sounds cool.
thanks
Bill
Old 11-07-2008, 01:49 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
Originally Posted by 92 Z-28 Camaro
Hi Folks
thanks
Bill
dont mean to steal the thread or anything but,
What do you have for heads/exhaust/injectors/fuel pressure/and intake???
Old 11-08-2008, 06:48 AM
Car: 1992 Z-28
Transmission: auto
Hi is the info on the car
TIMESLIP #1 60' =1.80 660' =8.25 1320' = 12.93 @ 106.43
Edelbrock pocket ported heads, LT4 HOT Cam, 1.6 RR, ported SLP runners, port matched base, 24# injectors, holley fuel pump, 52mm TB, AFR (43#), MSD 6A, Custom Chip (Superchips), SLP headers (Hot Jet coated) and exhaust system, 2000 stall converter, B&M shift kit, home made cold air kit, Edelbrock trailing arms, 3.73 gears, and drag Radials
thanks
Bill
Old 11-08-2008, 07:52 AM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
That sounds really nice and throaty. Classic V8 soundtrack...
Old 12-29-2020, 01:54 AM
MurderedZ28's Avatar
hey man just wondering what are the specs of the matching springs because I’ve been looking and can’t seem to find them thanks. Watched your video and that sounds bitching
Old 12-29-2020, 08:24 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
NM, didn't check date on necro'd topic.
Old 01-06-2021, 12:19 AM
Hey everyone I’m looking to do a cam in my l98, I understand that head work is good if I want more lift but I am ok with the stock head as is I’m looking to get this one (Comp Cam Nostalgia Plus Camshaft
Part Number 249-SK12-671-4) here are the specs
Lift: .468"/.462"
Duration: 276°/283°
Lobe Separation Angle: 112°
RPM Range: 1800-6200
I’m pretty sure this should work from the research I’ve done but I wanted to reach out to double check thanks in advance for any reply’s
Old 01-06-2021, 07:29 AM
Lift: .468"/.462"
Duration: 276°/283°
Holy HELL no.
Freaking 229° @ .50" on a TPI? Might as well shoot your engine with a Barrett 50 cal.
Start a new thread. new car, new starting point, new thread.
Old 01-06-2021, 08:42 AM
Abubaca's Avatar
Car: 1988 Iroc
Engine: L98 350
Axle/Gears: Hawks 8.8 - 3.73
I ran a zz4 cam and springs in my otherwise bone stock L98 an was very happy with it. Had enough lope to know there was a cam in there, but not much. Little more lift than that cam you listed, but way...WAY less duration. You really need to read up and understand what a TPI engine wants.
I learned a TON from reading this book. The parts used are all pretty old and outdated, but the concepts are 100% spot on.
https://www.abebooks.com/John-Lingen...MaAizEEALw_wcB
89 irockz
07-06-2012 01:25 PM
bigbird89
07-17-2008 06:55 AM
DirtyracingGTA
09-11-2007 04:46 PM
cubemaniac
03-25-2007 03:17 PM
Nasty_Bird_'90
06-14-2002 05:51 PM
Quick Reply: Best Cam for a 350 TPI
