Brands Brands Brands! Does anyone have any info?
Old 11-01-2008, 05:34 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I need to replace my tie rod ends and center link in hopes of correcting my shitty steering problem. I want good quality parts, but some of these prices seem EXCESSIVE. So I'm trying to find out if anyone knows anything about all these brands. I know Moog is considered to be the "best" replacement parts and that Moog is made my Federal-Mogul. When I was comparing prices with O'Reilly Auto Parts (who carries Moog) with Autozone and Napa I noticed something. The part numbers are all almost identical, except maybe a letter and the warranty. I've got Moog from O'Reilly's, MRC from Napa, and Duralast from Autozone. I know part of the difference between the Duralast and Moog parts are that the Duralast parts have shitty boots, but that wouldn't be a problem because I've got ES polyurethane boots. O'Reilly's also has Master Pro parts which have the EXACT same part number as all the Moog and still a lifetime warranty for MUCH cheaper, too. Does anyone know if there really is any difference between these parts or not? As far as I know all the parts are made by Federal Mogul, but I suppose they could all be made in different ways.
Here's a little rundown:
O'Reilly (Moog):
Inner Tie-Rod: ES2227RL $46.99
Outer Tie-Rod: ES2226RL $28.99
Center Link: DS1049 $99.99
Total: $251.95
O'Reilly (Master Pro/MPC)
Inner Tie-Rod: ES2227RL $24.99
Outer Tie-Rod: ES2226RL $14.99
Center Link: DS1049 $39.99
Total: $119.95 + tax
Autozone (Duralast):
Inner Tie-Rod: ES2227L $36.99
Outer Tie-Rod: ES2226R $31.99
Center Link: DS1049 $49.99
Total: $187.95 + tax
Napa (MRC):
Inner Tie-Rod: ES2227L $21.49
Outer Tie-Rod: ES2226R $21.49
Center Link: DS1049 $52.99
Total: $138.95 + tax
Advance Auto (TRW):
Inner Tie-Rod: ES2227L $33.99
Outer Tie-Rod: ES2226R $25.99
Center Link: DS1049 $70.99
Total: $190.95 + tax
Rock Auto (Moog):
Inner Tie-Rod: ES2227RL $36.79
Outer Tie-Rod: ES2226RL $22.79
Center Link: DS1049 $77.99
Total: $197.15 + $14.52 shipping - $9.86 = $201.81
Old 11-01-2008, 10:27 PM
1988-305-tbi's Avatar
Re: Brands Brands Brands! Does anyone have any info?
you forgot this part form rockauto: idler arm ...MOOG Part # K6249 , thats 75% of your total steering slop right there, plus search for "rock auto discount" for the 5% discount codes, it's worth it!
Scott
Old 11-01-2008, 10:43 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Axle/Gears: 3:73s!
agreed with the post above, Fix whats bad. If you want to redo everything, I used TRW from Advanced, also made by fedual mogel. I got new balljoints, all 4 tierods, adjuster sleeves, idler, and center link.
Old 11-02-2008, 07:05 AM
Car: 2012 Corvette
Engine: LS3
I don't need an idler arm, that's already been replaced with a Duralast part. Everything has been replaced but the strut mounts and the tie rods and centerlink and I still hate driving my car because the of steering. I don't see that the strut mounts have much affect on the way the car steers as long as the alignment is right so the only thing left is tie rods and the centerlink. Yes I know I need to replace the strut mounts, but I can't spend that kinda money right now, and to be honest I'm really tired of spending money and this problem not getting better.
I found the 5% off code for Rock Auto and that brought it down to $201.81. I'm going to call O'Reilly's (I may call a few stores to get different opinions) when they open later today and ask them if there's any difference between the Moog and the Master Pro. Since I'm sure they'd make more money off the Moog stuff, it'll be interesting to hear what they have to say. If they say to get the Moog stuff, I'll just buy it from Rock Auto since it's only $10 more than Autozone and Advance now.
Old 11-02-2008, 01:17 PM
Car: 2012 Corvette
Engine: LS3
Alright, I called O'Reilly and he said the Moog parts are made in America whereas the Duralast, Master Pro, and the like parts are made in Taiwan. He also said the Moog parts are made with a better material and have better dust boots. So I think I'm going to buy the Moog parts from Rock Auto, unless anyone knows anywhere cheaper.
Old 01-14-2013, 08:29 PM
JustJosh's Avatar
Does anyone know anything about the Moog complete strut assemblies found on rockauto.com MOOG Part # ST8515L ? Moog does not offer a "strut-only strut", so I wonder who makes the strut in the Moog complete assembly?
Old 01-15-2013, 12:10 PM
blakecharles's Avatar
I used Movetech from rockauto to rebuild my steering. I got all the following for about $120. It feels about the same as the stock parts that came off the car. They are made in Canada
- inner tie rods
- outter tie rods
- center link
- idler arm
- swaybar endlinks
this was taken from the Movetech thread
https://www.thirdgen.org/forums/susp...ng-anyone.html
Originally Posted by blakecharles
I got multi colored bushings too. some blue some black... kinda wish they where all blue
I'm rockin UMI adjustable tie rod sleeves
Old 01-15-2013, 11:25 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
AutoZone's Duralast is made in Mexico I believe. If anyone goes with them I recommend installing the parts and thoroughly looking them over afterwards. You may have to go through one or two but when you get a good part, the quality is good.
Old 11-03-2018, 01:22 PM
Michael Woosley's Avatar
sure, you might save a few bucks, but what most don't consider is the convenience of buying local. Just let the Rock Auto part go bad once, and you'll wish you bought it locally, just sayin'
Old 11-03-2018, 02:53 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Suspension parts on our cars are a pretty safe bet. As long as the boot is in good shape and they are greased at regular intervals they will last a long time. It's when the boot cracks and dirt gets in or it never gets greased that they go bad quickly. In that case a sealed joint is best.
Old 11-04-2018, 07:11 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Honestly I know your on a budget but save your money and go moog. Get it on rockauto and do it once.
Silver Spear
South East Region
18
12-04-2015 09:59 PM
Stryker412
09-20-2015 06:59 PM
wigmobile
09-17-2015 03:38 PM
SG91camaro
09-05-2015 10:27 PM
UltRoadWarrior9
09-02-2015 08:24 PM
Quick Reply: Brands Brands Brands! Does anyone have any info?
