round headlights for thirdgen
Old 10-31-2008, 12:08 AM
chevylove87's Avatar
Car: 87 camaro
Transmission: 700r4 shift kit
is there round headlights for the thirdgen camaro? and if there is where can i get them
Old 10-31-2008, 02:02 AM
nimrod_sixty9's Avatar
Car: '91 RS Camaro
Engine: 5.0 TBI
Transmission: Manual
Axle/Gears: 3.08
Re: round headlights for thirdgen
Never seen anything but im sure you could fab something up... What kind did you have in mind?
Not to thread jack but im interested in the guy who had 2 solid rectangular headlights rather than 4 square ones. He had a teal Camaro with a very nice wing. Id like to know what he did and how. Also interested in the wing.
Old 10-31-2008, 02:17 AM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
he probably took the headlights off of something like my fathers truck which is a 1993 chevrolet c1500 and fabbed them in, instead of sealed beams it goes to composite headlights which is great because then you can change a bulb in just a twist. the older 1500 series pickup has four square headlights like our third gens so i would not doubt one bit that it wouldnt be very simple to installed pickup truck headlights into place.
Old 10-31-2008, 02:20 AM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
I barely remember but I think I read somewhere, probably on his cardomain, that they came from a buick. Id really like to find out who this person is, cuz I still want to know about the wing as well.
But I do see what you mean. They may work. Im trying to think of someone I know who has that truck so I can inspect.
Interesting how they did that. Early 90's Gran Prix HL's. Thanks for the link dave.
Old 11-28-2008, 07:27 PM
1LOMARO's Avatar
Car: 89 Camaro, 94 z-71,98 Camaro
Engine: none, 350 tbi.sixxer
Transmission: none, 4l60e,auto
Axle/Gears: none, 3.73
I saw an article on the fall 2003 Camaro Performers publication where this was done to an 88. The guy used the sealed beams out of an 87 Monte Carlo....it is a sweet looking mod .
Old 11-30-2008, 06:53 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Looks like a late 80's Buick Lesabre, with the rubber seal around it.
Old 11-30-2008, 06:59 PM
1LOMARO's Avatar
Understood..... I was just saying that I've seen it done with Monte Carlo lights...... those actually look like Beretta or Corsica..... or something along those lines!
Old 11-30-2008, 07:46 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
I used Pilot foglights with a 10000k HID kit modification for my headlight conversion. You can see a pics here https://www.thirdgen.org/forums/atta...icture-012.jpg and here https://www.thirdgen.org/forums/atta...cture-012a.jpg
Old 11-30-2008, 08:25 PM
89T-top's Avatar
Car: 89 camaro rs
Engine: 3970014/block 350
Transmission: 700r4/shift kit
Axle/Gears: 2:73/going with 3:73's soon
I love the way that looks, the hole car in general.
Old 11-30-2008, 08:46 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
do you have any more pics of that. Ive seen many headlight conversions but thats the first time ive seen that one
Old 12-03-2008, 05:37 AM
AE Twitch's Avatar
Just curious; what size fog lanp did you use for the headlights?
Old 12-03-2008, 10:18 AM
JD_87Formula's Avatar
That's pretty sweet.
Old 12-03-2008, 09:29 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I don't think I seen that one either. Maybe a frontal picture from afar.
Old 12-08-2008, 11:29 AM
EKCamaro's Avatar
[o
Does anyone have more pics of this car....VERY interesting...different.
Old 12-08-2008, 12:59 PM
pwdbychevy's Avatar
They are the Pilot foglight PL-704c and the specs are attached. I have two sets of them. The high beams are PL-704 amber.
Attached Thumbnails round headlights for thirdgen-k8pil898.22.jpg   round headlights for thirdgen-k8pil898.22.1.jpg
Old 12-08-2008, 02:59 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The one using monte carlo headlights is "fatal88", he is/was? a user on here.
I have also seen the truck headlight ones done.
Old 12-08-2008, 04:14 PM
Curtisyz54's Avatar
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
On that blue car, they look like 90's Beretta lights.
Old 12-21-2008, 10:33 AM
AE Twitch's Avatar
Thanks, I was actually thinking about using PL-1093W for mine and I was going to convert my bumber signal lights into 6000k halogen fog lights.
http://www.pilotautomotive.com/Produ...7179&PCID=1057
Old 12-21-2008, 11:00 AM
daveSS1987's Avatar
Hi, I have a 1987 El Camino SS and have been working on installing a single unit headlight. !LOMARO said that 87 Monte Carlo lights would work, I have not found any that fit yet, the lights on the Monte SS and standard Monte are both 4 rectangle lights like the Camaro. I believe they use the same plastic mount for the headlights. It might be the Monte CL that had the one piece light but I have never seen these or how they would fit. The lights I bought were from a 1989/90 Corsica, Lauren makes fiberglass brackets to bolt them right to the Monte SS or El Camino SS nose, probably they also make them to fit the Camaro but I have not seen it done yet.
Dave
Old 12-21-2008, 11:54 AM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Every time I look at a camaro with the nose and back bumper/tail lights off I dream of making a custom first-gen style front/rear with round headlights and the 1st gen tail lights with a blacked out rear panel. Would look awesome (and kill the aero up front). Would probably look like a car GM would build as a 6th gen IMO.
Old 01-01-2009, 06:49 AM
andrewmp6's Avatar
The last of the chevy celebrity headlights most monte carlo owners use.The luxury sport monte carlo had the composite ones good luck finding those cheap.
Old 01-01-2009, 09:39 AM
daveSS1987's Avatar
andrew is right the Monte Carlo LS ones might work but they are very hard to find, even on the Monte SS site I never see them for sale.
Dave
Old 01-09-2009, 08:24 AM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
Dave
The Monte SS headlights are 82-92 Camaro headlight buckets, trimmed and with a bracket added. Lauren used to make them for Celebrity lights; I didn't know they fit for Corsica lights.
Old 01-10-2009, 09:31 AM
daveSS1987's Avatar
jmd - you are correct...I made a mistake, they are Celebrity headlights that I have. (hard to keep all those late 80's midsize chevys straight since other than the headlights I have no interest in the FWD sedans!)
Dave
Old 01-10-2009, 10:25 AM
Rick1805's Avatar
Car: 1992 Camaro
Engine: small block chevy 355/300hp
I used headlights from a astro van had a more flat lens that fit well in the opening I know there not "round" but other then using driving lights behind a plexi
Old 01-10-2009, 01:12 PM
UDAMON's Avatar
Car: Mazda Protege5
halo projectors from a silverado. 1 piece style like above.
Old 01-10-2009, 01:14 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Thats looks pretty good UDamon!
Old 01-12-2009, 02:31 PM
lonesomecrow's Avatar
Car: 92 RS
Axle/Gears: ??
I love the look of this. How much of a pain in the rear is this to accomplish?? It is something I had in mind but dont know if I will be able to do it.
Old 01-12-2009, 02:40 PM
UDAMON's Avatar
Car: Mazda Protege5
thanks!
it wasnt bad at all but requires cutting(more like carving out) the factory header panel. i dont have more pictures right now but if the weather breaks ill be able to get more detailed shots.
Old 01-12-2009, 08:13 PM
jon 89 RS's Avatar
Car: 89 camaro rs
Engine: 2.8L
just curious is that the 82-92 camaro sniper front bumper? got other pics?
Old 01-12-2009, 08:42 PM
Rick1805's Avatar
Car: 1992 Camaro
Yes it is
LOL Many more pictures of my build
http://www.cardomain.com/ride/2573014
Old 01-14-2009, 03:54 PM
Car: 92 RS
Axle/Gears: ??
thanks!
OK man thanks. It is definitely not good to work in a car during bad weather, 2 weeks ago I changed the engine oil and lubed the chassis on my RS and ended up with a pretty bad backache.
Old 01-14-2009, 05:40 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
thanks!
what yr. silvy?
Old 01-14-2009, 06:04 PM
UDAMON's Avatar
Car: Mazda Protege5
Originally Posted by NemeSS-TyranT
what yr. silvy?
auction states 94-98
Old 02-09-2009, 08:30 PM
Erwilliam's Avatar
Car: Chevy Camaro IROC Z Z28 1987
hey how u doing , im looking for halos for my iroc z,, where can i find those, do u know?
Old 02-15-2009, 01:55 AM
chindo's Avatar
Car: 1976 Trans An
They all look nice. i have been planning on using two round lights so i could have a little room for some air to flow passed into a CAI. Nothing set in stone but plenty a drawings and planning, and maybe something that looks good will fit.
Old 02-17-2009, 06:24 AM
Desarial's Avatar
idk I noticed you trying to find round lights, you could probably fab something definately. and the halo lights will have to come off a truck, maybe a late s10 or something simalar that's chevy. I've noticed chevy is fairly lazy when it comes to new measurements so alot of stuff fits together well, a little trimming or a little adding and it should fit snug liek the stock lights. for having a single unit it looks like the headlights from a 89-94 nissan maxima would work, they've got about the same curve to them as the fore front of a third gen bumper and the fit would be near perfect. I only know cause I had on. I'm not sure about replacing the bulb though, can't remeber if it's sealed beam or not. I do know they have a little hose on them ti let out moisture and pressure, so you're light wont end up malformed or oxydized. I don't know much about cars but I'm good with electronic and wiring so if anyone has more questions I'll try to help as best I can.
Edit: forgot to mention, the nissan head lights have a single light for both low and high, might be dificult for some addaptation, but it's easer when replacing bulbs. depends on your pref I guess
I do alot of editing: I just did a search to throw in some examples of s10 lights that will work, but most of the halo lights wrap around and the corner light is one peice. I'm not sure which year it was but there's one where the corner light and headlight are separate, IKNOW they hve halo lights for them cause I've seen them around. there's a gut that stops in a gas station I used to work at that had it set up like that. and below is a link to after market HID sealed beam kits, should help with fabricating a round lamp setup. http://www.automotivelightingusa.com...index&cPath=39
Old 02-17-2009, 08:40 AM
ssean92's Avatar
Car: sold
I have been thinking about doing this, well now I think this will be the next mod I do. I read your write up on your cardomain and it looks real easy.....Cleanest headlight mod I have see as of yet
Old 02-17-2009, 09:05 AM
AE Twitch's Avatar
I changed my mind on the round headlights. Found a set of diamond cut lights and also some turn signals to match.
Old 02-17-2009, 09:08 AM
AE Twitch's Avatar
I also have the bumper lights and side markers with a smoked lens, not sure which one I like better.
Old 02-17-2009, 10:06 AM
Stephen's Avatar
Car: 87 GTA
Fatal88 did the 1-piece headlights almost 10 years ago. Along with the LT1 (LS1 didn't even exist then) & 4th gen dash. I saw it at the GM Classic Tour they were doing at various shows. I saw it down by Houston, in the mid 90s.
Fatal88 hasn't logged into TGO in just over 2 years now.....
Old 04-29-2009, 07:18 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
awesome conversions
Old 04-29-2009, 11:05 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
how about the light year one is using in their Bandit car.
It has a round look on the low beam and a standard on the high beam. I'm not sure about it fitting in the space but could be an option.
Old 04-29-2009, 11:26 AM
KITT1983's Avatar
oh pretty pretty shiney shiney nice
that looks awesome very knight rider
Old 04-29-2009, 11:34 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
well, I'm not sure how it makes it night rider but it is a great improvement on the smokey and the bandit car.
http://www.yearone.com/yodnn/Portals...ry/407/306.jpg
Old 04-29-2009, 12:39 PM
KITT1983's Avatar
Anything that would be on a Rice Rocket and that looks awesome on American cars.
-Knight Rider
KITT had neon underglows, leds, and other fancy accerories such as tvs
Old 04-29-2009, 01:00 PM
Former Sponsor
1Aauto's Avatar
That light setup on Rick1805's car looks like it fits right in there.That's a nice clean looking setup.
Old 04-29-2009, 02:53 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
What year astro van? They probably make some aftermarket lights for it.
Old 04-29-2009, 03:13 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
http://www.buyautolights.com/8899-gm...ar-p-4924.html
http://cgi.ebay.com/ebaymotors/88-98...Q5fAccessories
these are for full size gmc trucks, looks alot like what yearone is using on the bandit car.
Old 05-06-2009, 08:22 PM
mr.lanston's Avatar
Car: 1984 Z28
Engine: 383 stroker
Transmission: beefed up 700R4
Axle/Gears: stock just for now
hey i just joined and i'm really impressed by your astro van headlight mod if you don't mind could you go into more detail as to how hard it is to do please post it thanks alot owner of a 1984 z28 in rehab lol
Quick Reply: round headlights for thirdgen
