700R-4 Wont shift outta first gear.
Old 10-18-2008, 01:18 AM
Beggins's Avatar
Car: 1987 Trans Am GTA
Engine: 355 TPI
Transmission: 700R-4
Axle/Gears: 10 bolt limited slip with 3.42
I just installed a 700R-4 I got into my Trans Am. I got a TPI 350. Whe I went to test drive it, it took off fine then got up to 25 mph and wouldn't shift period. When I let off the gas and get back into it it wont kick back into until the RPM I let off the gas in. I am seriously lost here... Any help you guys could give would be appreciated.
Old 10-18-2008, 01:31 AM
fbody5's Avatar
Re: 700R-4 Wont shift outta first gear.
is your tv cable hooked up and adjusted properlly
well i don't know if the setup is the same for tpi but on the carbs and tbi i know it is
Old 10-18-2008, 06:06 PM
Beggins's Avatar
Engine: 355 TPI
It's hooked up and adjusted according to the GM Service manual
Old 10-18-2008, 06:18 PM
mmather1's Avatar
SOunds like a problem with your governor. there is a round cover near the back on the driver side of the trans. Use a hammer and a screw driver to get the cover off, you will probably find that the gear is worn on the end of it or the valve is sticking in the governor
Old 10-18-2008, 07:36 PM
Stephen's Avatar
Car: 87 GTA
Sounds familiar.....17,000 miles on my rebuild & suddenly it started requiring 4000+rpms to shift.
After adjusting my TV per my 87 FSM, no change. Fluid & filter change...No change.
It gear, it HOLDS & the tires (285/17s) are history...Just NO upshift.
Governor?
Old 10-18-2008, 07:50 PM
mmather1's Avatar
Ya the governor controls the shift points, and its common for the gear to wear off (plastic) if it does the trans will not upshift.
Old 10-19-2008, 05:26 AM
Beggins's Avatar
Engine: 355 TPI
Thanks guys I got it shift now. but my shifts points are all messed up. I am thinking I have to play with the governor to get it set right. any ideas ???
Old 10-19-2008, 08:25 AM
mmather1's Avatar
you can change the springs in the governor, the lighter the spring the later the shift, heavier the spring earlier the shift, Also if you want even later shifts and the springs already really light you can grind some of the weight off, The easiest method would be just to order and Corvette governor though, but if you don't mind messing around then find some springs and go at it.
Old 10-19-2008, 09:39 AM
Stephen's Avatar
Car: 87 GTA
How'd you get your shifts back? Mine was off & on, and now nothing.
Old 10-19-2008, 11:19 PM
Beggins's Avatar
Engine: 355 TPI
The governor was missing outta the transmission... I put in a new one it's working great just need to get stronger springs. Cause mine is shifting some where in the 3000 rpm range.... I am really not liking that.
Old 10-19-2008, 11:31 PM
Stephen's Avatar
Car: 87 GTA
Thats encouraging news (for me), suggesting that my governor gears just stripped out.
I'm pulling the cover off tomorrow & looking.
Where'd you get the governor? (I case I need a new one)
Old 11-22-2008, 12:53 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
i pulled mine out today i think the plunger is getting stuck in it if thats the case is it time for a new one?
Old 11-22-2008, 01:46 PM
On Probation
Atilla the Fun's Avatar
Car: seeking '90.5-'92 'bird hardtop
Engine: several
Transmission: none
Axle/Gears: none
you can get them from any local transmission shop, like Aamco.
Old 11-23-2008, 12:14 PM
Beggins's Avatar
Engine: 355 TPI
Here's what happened with mine. The transmission shop pulled the valve body off and there was trash in there that kept the check ball from working correctly. so they cleaned it out and installed a helper spring to go with that check ball.
Old 11-26-2008, 08:37 PM
Rick1805's Avatar
Car: 1992 Camaro
Engine: small block chevy 355/300hp
Ok after 2 years of sitting I was ready to take the camaro out for a spin and put some new gas in it. From what I was reading in this thread I seem to be haveing the same problem wont shift out of first. Anyone have a photo of what they had to do to the governor??? Or a link ????
I am hoping that this will solve the problem did not want to pull the drive train just yet
1992 camaro RS
305 TBI
Old 11-26-2008, 11:28 PM
Beggins's Avatar
Engine: 355 TPI
the govenor is located on the driver side of the tranny.... It's a round cover. You can pull the govenor with out having to pull the tranny....
Old 11-26-2008, 11:32 PM
Stephen's Avatar
Car: 87 GTA
Ummmmm......There is so little room between my governor cover & the tranny wall, my hand barely fits in there.
No way the cover is even coming off, much less the full assembly.
Old 11-27-2008, 10:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The governor comes out with the trans still in the car. I remove the crossmember to get it out of the way along with being able to drop the rear of the trans a little (just a little, don't wack the firewall with the distributor).
RBob.
Old 11-27-2008, 02:47 PM
Rick1805's Avatar
Car: 1992 Camaro
Ok got mine out without removeing the crossmember was close but it came out lol needs a new cover seeing it was rusting away and first hit put a hole in it but there is around 5 or 6 inches from the cover to the floor pan. the gear was fine but the wings seems loose and weak anyone know if there just suposed to flop around or have tension on them ?
Old 11-27-2008, 11:11 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
They do flop freely. Hold it on end and be sure that the weights are pushing the spoolvalve INSIDE up in the bore. And be sure the spoolvalve INSIDE freely returns to the postion.
There are 2 parts to the 'wings' with a spring inbetween them. Be sure those little springs are keeping tension on the 2 'wing' peices.
If you have drastically changed gear ratio or are looking to time the shifts sooner or later, then you can get a Governor Recalibration kit from B&M. It comes with a few different srpings and weights, as well as 2 new holing pins and e-clips to make it future servicable. Instructions are included but usually takes a few tries.
Clean the parts with mineral spirits and dry.
Old 11-28-2008, 03:10 PM
Rick1805's Avatar
Car: 1992 Camaro
Ok so the wings flop freely and the spoolvalve when held gear up moves freely but if you turn it sideways it does not move with the "wings"
So if this from what I am reading looks to be fine what else would stop it from shifting out of first the transfluid looks to be fine I have not droped the pan yet and the TV cable for what it looks like is stock never been touched.
There is one strange thing and someone test this on there TV cable if possable when the cars at idle and in park I went under the hood and pulled on the TV cable there is a "vacuum leak / exhaust leak" sound
Old 11-28-2008, 03:28 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
just a ???? what does the GM S.M. say for adjusting the TV cable, i know oif you pull it back you will get firmer, later shifts and push it foward for softer early shifts but what is the Proper way to adjust it
Dustin Marlow (05-20-2021)
Old 11-28-2008, 03:39 PM
Rick1805's Avatar
Car: 1992 Camaro
Found this for the TV cable adjustments
http://www.tciauto.com/Products/Inst...ble_adjust.htm
Old 12-01-2008, 02:14 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
If governor doesn't fix your messed up shift points and a t.v. cable adjustment doesn't seem to you might have to pull the valve body and free up the throttle valve (not to be confused with the t.v. plunger). The plunger pushes the throttle valve internally in the valve body when the t.v. cable pulls. On high mileage 700r4's these throttle valves stick easy. The aftermarket has updated throttle valves with return springs to prevent this. You need to remove the valve body to do this because there is a second roll pin in the valve body that prevents the valve from coming out in the throttle valve area. You could remove the outer plunger and bushing by removing the outer roll pin with dikes and use a strong pocket magnet to try and free up the throttle valve with patience without removing the valve body. If it doesn't have a return spring it will probably get stuck internally again so it would probably be better to just pull the valve body and upgrade it.
racereese
10-03-2015 03:46 PM
gord327
10-03-2015 01:25 PM
Spyder_TheGamer
10-02-2015 12:25 PM
Jlanz55
09-29-2015 08:55 AM
mfp189
09-27-2015 09:25 AM
Quick Reply: 700R-4 Wont shift outta first gear.
