Paper gaskets and/or sealant?
Old 10-08-2008, 09:05 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Ok, this may be a stupid question.... What do you use with paper gaskets to get a good seal i.e. timing cover, water pump t-stat? I have used RTV with these gaskets but if I am using RTV, then whats the point of the gasket? I tried some sort of tack seal for paper gaskets and it was crap. I also heard a rumor that if you use RTV with a paper gasket, the gasket can get soaked with oil and separate from the RTV and actually move between the thin layer of RTV during heating and cooling, which causes leaks. Any thoughts?
Old 10-08-2008, 10:04 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
A light coat of gasket sealer, gasket cinch, etc. I use Permatex Gasket sealer: Aviation Form-a-gasket http://www.partsamerica.com/ProductD...egoryCode=2132 .
Old 10-09-2008, 04:25 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Paper gaskets and/or sealant?
I've never used sealant on paper gaskets.
With flat surfaces and proper torqueing you should have no need for it.
Old 10-09-2008, 09:40 AM
kcb37's Avatar
I agree with Viprklr.
I don't use anything with them either.
Old 10-09-2008, 10:53 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I put a skim coat of RTV on them.
Old 10-09-2008, 01:25 PM
five7kid's Avatar
Engine: LS1/LQ4
With flat, smooth surfaces and proper torquing you shouldn't need a gasket.
Old 10-09-2008, 01:51 PM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
I only use sealant as a glue to hold paper gaskets in place. Just a dab or two.
On a side note I prefer to use "Reusable" gaskets on thermostat housings. I have seen these seal more reliably and you can play with your thermostat temp until you get it right without replacing the gasket over and over.
Old 10-09-2008, 03:16 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
So just use the paper gasket by itself? No sealant or gasket dressing?
Old 10-09-2008, 04:52 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
I do the opposite for the "paper gasket" areas, ie water pump, timing cover, -- no paper gasket, just Permatex Right Stuff. If it's good enough for modern OE's, it's good enough for me. Plus it makes setting thrust button clearance easier w/ retrofit roller cams, if you don't have to factor in timing cover gasket squish.
sheachopper
07-31-2019 11:27 AM
tyeo098
11-30-2015 06:27 PM
Aaronv808
Members Firebirds
09-30-2015 12:55 PM
hdis2002
09-08-2015 02:52 PM
Quick Reply: Paper gaskets and/or sealant?
