what size wheels/tire are you guys running?
Old 09-21-2008, 05:24 PM
GTAwheelman's Avatar
Car: 1985 Sport Coupe
Axle/Gears: 3.08
i'm thinking about getting these rims from summit, but i'm unsure what size i want. i would like that big N little look but i dont want the front to be too small as i would like the car to corner decently. i dont want the rears so wide i have rubbing issuses.
Old 09-21-2008, 05:32 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: what size wheels/tire are you guys running?
im bout to be running some 245/45/17s up front and 315/35/17s out back on the IROC cant wait
Old 09-21-2008, 06:57 PM
88bird?'s Avatar
Car: 1988 Pontiac firebird
Engine: built 350
Transmission: 700r4 built up to 600hp
Axle/Gears: stock for now
If i were you id go with 15x5s front and 15x8s rear if you dont want problems, i have 15x3.5s and 15.10s and i had to roll my fenders and convert to manual steering, it was worth it to me but with the first two sizes i listed you shouldnt have any problems.
Old 09-27-2008, 10:49 AM
CamaroBeast's Avatar
I run 245.45. wraped in 16'' Torque Thrust II and then 16'' on front in smaller tire of course
i run 245/45 in the back wrapped with 16'' American Racing Torque Thrust II. and 16'' on front two with smaller tires.
Old 09-27-2008, 02:28 PM
Axle/Gears: 3.08
they sound like a good combo (5s and 8s). i had thought about running 10s in the rear but was afraid of rubbing. hmm i do some more thinking about what i want to run because i dont have the cash now to buy the rims anyways.
Old 09-27-2008, 02:39 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Engine: 305 Crossfire
Axle/Gears: 3:23
How will you be using that size for the rear ? I tried out some Corvette C5 rims that were that size for the rear, and there was no way they would fit without modifications done to the inner fender well and also, a spacer ??
Old 09-27-2008, 03:09 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Axle/Gears: 3:23
I am currently using 18" Crager SS rims. 245/40/18 up front and 275/35/18 in the rear. The front size tires are not a good choice as they are rubbing slightly inside the fender wall when making extreme sharp turns. I will be choosing another tire size setup up front. Any suggestions ?
Attached Thumbnails what size wheels/tire are you guys running?-18-inch-crager-ss.jpg   what size wheels/tire are you guys running?-img00193.jpg
Old 09-27-2008, 03:23 PM
kennyglm's Avatar
Car: 87 irocz
Engine: 5.0
255/50/16
Old 09-28-2008, 08:18 AM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I have 15 by 5 front and 15 by 10 rears with a 5.5 bs. I wouldn't try and road race it or anything but no problems taking any turns just driving around.
Old 09-28-2008, 11:46 AM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Got 18x8.5 with 235 40 18 (for now) front & 19x10 with 285 30 19 rear, also 2" adapters and inner rear fender hammer job. Later.
Old 09-28-2008, 12:05 PM
Stephen's Avatar
Car: 87 GTA
17 x 9 on all 4 corners...275s up front, 285s rear. Zero rubbing, zero interference. Zero body trimming was needed.
your asking about sizes, but that all depends on diameter & backspacing, nut just width, as evidenced by the guy running 315s o the FRONT.
Old 09-28-2008, 12:47 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
well ill be running some torqu thrust m 17x10.5 and ill use the required spacer and ill roll my fender and bang in my inner fenderwells if necassary ive read some post with people getting them just fine but recomended using tubular LCAs to provide more clearance....If they arnt direct fit o well im a good fabricator ill make them fit!! lol ill post pics when i get them all though im delaying them now cause all my money has shifted to an Gen III Motor Swap!!
Old 09-28-2008, 08:55 PM
HotRodLarry's Avatar
Car: '83 Z28
15x8's on all four corners. 235/60r15's up front, 245/60r15 in the back. Everything clears and with the 1/4" spacers I have in the rear, the car has that subtle "east coast stance" to it. Also, the tires stick out just enough where the white letters are flush with the fenders.
Linson
08-21-2015 02:12 PM
86IROC112
08-17-2015 02:00 PM
kyleb24
08-15-2015 08:24 AM
wruiz
08-13-2015 09:07 PM
knight72
08-10-2015 09:32 PM
Quick Reply: what size wheels/tire are you guys running?
