95 or 95 TA Cam???
95 or 96 LT1 Cam???
Which is overall the best cam? A 1995 stock LT1 or 1996 stock LT1 cam? I am upgrading from a stock 5.7L tbi cam.
I am installing Comp Cams 1418-16 roller rockers (1.6) with RHS heads with 2.02/1.60 valves 76cc chamber. 50mm ported edelbrock performer tbi intake with a 7.4L tbi base and cop car injectors (4327). 255pph fuel pump and afpr.
Need to know what the best cam is of the two that I have. I have looked at the following info on the LT1 cam threads, but not sure what to do. Help? Please? I have spent a few hours reading and now it's time to ask for help.
Thanks so much guys!!!
http://www.malcams.com/legacy/misc/CamData.htm
Re: 95 or 95 TA Cam???
Seems that I find 4 different "spec" charts for 94-96 LT1 cams. They "supposedly" were all the same. Who's right? LOL!!!
HELP!!!
Simple, I just want to know if the specs are the same between the 95 and 9 LT1 cams and if anyone "really" knows what they are.
HELP!!!
What would you recommend?
I know that either of the LT1 cams are a lot better than my stock 350 TBI cam. I want something easily tuneable, but something to match my intake, fuel system and heads.
Comp Cams??? Which one?
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Maybe a LT4 hotcam?
Try using the comp cams cam quest. Just google it, they made it free not to long ago and it rocks : )
itll help you, trust me
Well, I bit the bullet, lol!!! Just purchased a Comp Cams 8-304-8. The cam, heads and other mods should bring a strong 350hp!!! YES!!!
The 1.6 rockers should bring my lift close to .544
Will let you know when it's done.
Thanks everyone for your help!
