MY TH700R4 now won't shift?
Old 11-26-2000, 03:11 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
as you may recall My '86 IROC (new project car) had a bad transmission.so i took it out
found that the front pump had failed.replaced the front pump,and the cluthes with ones from a '91 60degree V6 that I had. I cleaned everything up real good.repualced the TV cable.Reintalled the trans.Then on my first test drive the trans would not shift out of first gear.played with the TV cable adjustment,even diconnected it. no luck.
here is my question;what do I check first?Maybe I have still not gotten some simple thin right?
THANX,ANDYZ28
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter. 9bolt 3.27 w/1LE rear brakes 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc
Old 11-26-2000, 03:23 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Could be something simple like the governer stuck or the teeth worn out, or it could be that when you dropped the input housing and reverse input housing into the trans, you forgot to make sure the 2-4 band was on the anchor or apply pin. If you redline the engine, will it eventually shift (into third maybe?).
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old 11-26-2000, 03:39 PM
ANDYZ28's Avatar
Car: 1982 Z-28
No! I did not go to the redline.But when I go to the point where it shoul have shifted and let off the gas.It acts like it is in neutral(no dynamic braking).But my '82Z did the same thing after I installed the B&M shfit kit when I would let off before reaching the shift point.
If it is the anchor pin,can i reset it without pulling the trans. again?
when we first got this car,and scared the hell out of ourselves driving it home.It would not shift then either.No problem,I just unhooked the TV cable and it would shift
.Way early,but it would shift.Even with the smoked front pump.
THANX,ANDYZ28
Old 11-26-2000, 03:47 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Hmm, sounds like governer problems. Take it to redline, and see if it still won't shift into any gear.
South East Thirdgen
Savannah, GA
'87 Trans Am
TB Coolant Bypass,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old 11-26-2000, 03:57 PM
ANDYZ28's Avatar
Car: 1982 Z-28
OK! Hold on I'll go out side and drive it.
I'll be right back.
Old 11-26-2000, 04:09 PM
ANDYZ28's Avatar
Car: 1982 Z-28
GMTECH,Yep! It shifted just shy of 5500 r.p.m. 1-2 and 2-3. I couldn`t get the 3-4
shift, as I was going way too fast in our
neighbourhood!(THAT WAS WITH THE TV DISCONNECTED)
Old 11-26-2000, 04:57 PM
ANDYZ28's Avatar
Car: 1982 Z-28
GMTECH,should I simply replace the governor?
my donor trans did not have one.so I reused my old one.
thanx,ANDYZ28
Old 11-26-2000, 05:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Hmmm, well, it shouldn't be the 2-4 band since it finally did shift. How was the 2-3 shift? At what RPM did it shift. Take it out and make sure it has 3-4 shift also.
South East Thirdgen
Savannah, GA
'87 Trans Am
TB Coolant Bypass,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old 11-26-2000, 05:54 PM
Blade's Avatar
Dude this is EXACTLY what my transmission is doing! LOL YOu said removing the TV cable works ? I'm gonna go do that right now then! LOL
Old 11-26-2000, 06:05 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Just returned from the road test.results:
the 1-2 shift has come down by itself somehow
to 4500RPM.
the 2-3 shift is about 4100 RPM
Old 11-26-2000, 06:07 PM
ANDYZ28's Avatar
Car: 1982 Z-28
sorry i did not finish my last msg.
the 3-4 shift is very poitive at 4000RPM.
Old 11-26-2000, 06:24 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yeah, its almost safe to say that none of the "mechanical" components are toast or defective. My guess would be valvebody problems, but since the governer is easier to swap out than pulling a valvebody, I would try another governer.
South East Thirdgen
Savannah, GA
'87 Trans Am
TB Coolant Bypass,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old 11-26-2000, 06:36 PM
ANDYZ28's Avatar
Car: 1982 Z-28
thanks GMTECH,I'll get another governor from my dealer tomorrow,install it tomorrow night
and then I'll let you know how I made out.
THANX,ANDYZ28
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side not too bad
Old 11-27-2000, 08:48 PM
ANDYZ28's Avatar
Car: 1982 Z-28
GMTECH,I took the governor out tonight.And sure enough it was stuck at about 2/3 travel.
So I took it apart and found many tiny metal chips in the upper most groove.Oiled it up and put it back in.I'll road test it tomorrow night.
THANX,ANDYZ28
Old 11-28-2000, 10:04 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Hey guys,I just finished the road test.And after cleaning the governor. The trans shifts just fine now. GM TECH thanx for all your help.
Old 11-28-2000, 10:44 PM
Danny P 86Z28's Avatar
You better find out where those metal chips came from beforeit messes up your whole tranny.
AmpleUnicorn88
Interior Parts Wanted
16
11-29-2015 05:45 PM
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
AmpleUnicorn88
09-24-2015 09:15 AM
camarohelp
09-22-2015 03:19 PM
junior419
09-22-2015 03:19 PM
Quick Reply: MY TH700R4 now won't shift?
