Twin turbo progress pics
Old 09-14-2008, 02:50 PM
  #51
92KRVZ28's Avatar
Car: 1992 25th Anniversary White W/ Red
Engine: Procharged 383CI/ Soon LS2 Turbo
Transmission: Manual 700R4
Axle/Gears: 4:11/Auburn Posi/Moser Axle
Re: Twin turbo progress pics
Running 1000+ hp is very well possible. i have a friend whos twin turbo c5 made over a 1000 at the rear and he drove around on nice days in town highway he even drove it to the track to race.
Old 09-14-2008, 02:59 PM
  #52
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
here in columbus there are at leat 10 cars i know of over 1000 whp. some are over 1200 and they are street cars. mor than they are raced.
3 are z06 on just went 9.66 at 155 on 9lbs of boost with 16 lbs made 1240 whp. he is on dr so bad 60 ft mid to high1.5s
Old 09-15-2008, 01:36 AM
  #53
TA88GTA's Avatar
Originally Posted by 85mcss
Some great craftsmanship and many of hours of planning have been put into this project and it shows.
Quick Q, though... What Thermostat housing is that? I also have an HSR w/58mm and I have been looking for a swivel type housing that will fit under the TB. All the ones i have found are too tall and run into the IAC housing. My IC tubing runs directly in front of the stock stat housing outlet forcing me to angle towards the passenger side instead of the drivers side. TIA!
The house is a CSR piece. But a shaved a ton of material off the backside to get it to clear the iac housing. I shaved material off my HSR to make it clear the stock hood and shorten the runners so i have alot less room from the thermo housin to iac housing than you would normally have. The csr piece should work fine for you and if not just shave it, there is tons of material u can remove safely.
Old 09-16-2008, 03:06 PM
  #54
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Very nice looking setup. No #'s yet?
Old 09-16-2008, 03:53 PM
  #55
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Very clean. This is one of the nicest jobs that I have ever seen. Lot of forethought and even more skill shows in this project.
Old 09-17-2008, 02:28 AM
  #56
TA88GTA's Avatar
Thanks,
Comfirmed tuning dates are now set for the 25 and 26 of this month. Will post numbers soon as there out.
On another note ive be doin some minor street tuning to shake out the bugs before the big day. U butt dyno says shes got got ***** lol. roll on to about 5psi at half throttle in third gear and it looks it someone hung two black paint brushes off the back bumper.
Old 09-17-2008, 03:40 AM
  #57
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
Originally Posted by TA88GTA
...it looks it someone hung two black paint brushes off the back bumper.
ha nicely put, looking forward to the numbers.
~Jeff
Old 09-20-2008, 12:19 AM
  #58
weberflorida's Avatar
Car: 1991 Camaro Z28
Really nice looking man
Old 09-25-2008, 08:09 PM
  #59
lt1z350's Avatar
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
sorry havent been on in a few weeks. Here is a few of my project that is almost done. I have uploaded pics and it wont let me reupload them. How do I move them over here from the thread "post your single turbo set up pics here" ? Any way you can see them there attached to my name lt1z350. or if someone tells me how or can do it for me and move a few over here.
Old 09-25-2008, 08:16 PM
  #60
Street Lethal's Avatar
^ You have to attach them using the new thirdgen.org link. Double click the attachment you made in the original post, then right click on it to cut and paste it's new properties....
Old 09-28-2008, 08:33 PM
  #61
TA88GTA's Avatar
So quick update. The car dynoed thursday friday along with a T trimed 421 camaro and badass Grand National. Thought the car was ready but of coarse if your gonna have problems, your gonna have them at the worst possible time. Anyways first day was shot after the plug wires caught fire and roasted some wiring. Over half of friday was wasted casing a possable fuel issue which turned out to be a spark issue. And once all that was figured out the and the car was again running on all cylinders we cased a boost issue for the rest of the day which still remains to to be sorted out. The problem is we would set boost at 20psi and it would boost to 5psi immediatly and then creep in to 14/15psi max over the rpm band. The boost controller wasnt working correctly and i believe the wastegate springs are too small for the boost we were trying to achive so were gonna give this another try to after i up the WG springs. At 15psi the mustang dyno is telling me were putting out 630 to the wheels but im not gonna concern myself with the numbers untill the problems are sorted out.
Also anyone ever used a mustang dyno. Owner of the grnd national told me he talked to a few people who said they call it the soulcrusher cause the tend to read low. Just wondering if anyone knew if there was some truth to this.
Old 09-28-2008, 09:07 PM
  #62
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Awesome buildup man! I'll be keeping an eye on this one!
As for Mustang Dynos...yes, the general consensus is that they do read lower than DynoJets and such. However, IMHO, they are more repeatable, and, since they are a loading dyno, much more useful for fine tuning drivability. Most people say they read about 30 HP "low", but the difference may be larger at your HP levels
-Paul
Old 09-28-2008, 10:00 PM
  #63
TA88GTA's Avatar
I see, thanks for the info. Either way, who is to say if the mustangs are reading low or the others are reading high.
Old 09-28-2008, 10:07 PM
  #64
quadgoat's Avatar
Car: 1992 Firebird
Very true The most important thing is that you pick your dyno and stick with it throughout your tuning. That way when you make changes you can see whether you gain or lose power. "Dyno racing" is a somewhat pointless waste of time
-Paul
Old 09-29-2008, 11:58 PM
  #65
TA88GTA's Avatar
So the boost issue is fixed. Problem was just lack of spring pressure in the gates. Car spools perfect now. Will have final numbers soon.
Old 10-28-2008, 09:13 PM
  #66
TA88GTA's Avatar
Hey guys, update on the car is i had her back on the rollers for the second time and she put down 788@ 19psi. Ended up battling and few more issues and running outta time but im happy thus far and ill be bringing her back for the 20+ psi tuning. I had dyno video which i was gonna post but it got recorded over accidentaly. I do have some street video, so here you go. The last vid is a 4th gear roll on throttle and an accidental lane change at about 130km. Sorry for the shoty camera work but i dont blame him for wanting to grab the cage at that point lol. 1st through 4th are useless without the traction control setup.
Enjoy!!!
Old 10-28-2008, 10:30 PM
  #67
dark_daku89's Avatar
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
whoa!!!
Old 10-28-2008, 10:52 PM
  #68
AC
AC's Avatar
Car: Used to drive a camaro
Holy SNART, I just SHART myself. Very nice man. Damn, turbos are so much fun it seems. They "almost" pull me away from buying my F1 procharger this spring.
Old 10-28-2008, 11:10 PM
  #69
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Awesome! So, youre running xfi? What are your intercooler dimensions? Thanks!
Old 10-28-2008, 11:33 PM
  #70
online170's Avatar
Car: 1987 Firebird
:O thats a very clean car. I didnt think the rest of it would be that clean
Looks scary, and it doesnt look like you were gassing it much. Prolly not a bad idea to get some track time with it to 'really' practice driving....
Very very nice.
Plus... I know someone will ask down the line, so ill go ahead and ask now anyway. Size, dimensions and make of wheels and tires? Those look amazing on the car!
Old 10-28-2008, 11:44 PM
  #71
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
I was going to ask the same question^^^^^ THose wheels are awesome!!! But the whole car of course is just amazing!!! You must have fun in that car!!
Old 10-30-2008, 03:15 PM
  #72
TA88GTA's Avatar
Yes im running the FAST XFI w/ traction control and the intercooler dimensions are 30/12/3.5
Tire sizes are 19by10.5 rear and 19by9.5 fronts. Backspacing was measured wrong so im running a 1/4spacers all around to make them work
Thanks for all the compliments again guys its been a few years in the making but shes almost done.
Old 10-30-2008, 04:34 PM
  #73
Demon355's Avatar
That thing is truly a badass machine. You can hear the boost coming in and then seeing the nose of your car dart into the next lane hahah priceless!
Old 10-30-2008, 09:03 PM
  #74
Thank you, TA88GTA! What kind of mods did it take to get it to fit? (Other than lowering the radiator) Love the car!
Old 10-31-2008, 12:54 AM
  #75
TA88GTA's Avatar
Well other than cutting all of the lower rad support out and lowering the rad, we trimmed the upper rad support which you can see in the first vid and welded the mounting tabs to the sides of the IC. Really didnt take much work. We installed threaded inserts right in the frame rails so the mounting plates sit flat on the bottom side of the rails and are bolted right to them.
Old 10-31-2008, 07:26 AM
  #76
online170's Avatar
Car: 1987 Firebird
how is your quest going for fresh air? I know you wanted to cut up the front a bit and feed it some air.
Old 10-31-2008, 02:23 PM
  #77
TA88GTA's Avatar
Actually pretty good, we fabbed up an aluminum air scoupe that catches and diverts air to the IC and rad seperatly. It been workin pretty well but hangs a little low so were gonna fab a new one that doesnt scrape driveways as much.
Old 10-31-2008, 05:39 PM
  #78
icebird84's Avatar
Car: workcar Legacy Cruising 84 trans am
Engine: Ls1 99 corvette
Transmission: update working to get a T56
Axle/Gears: 2004 GTO IRS
so no cooling or airflow problem ?
scoupe is it Mounted on the cooler or inside the nose
Old 10-31-2008, 08:52 PM
  #79
TA88GTA's Avatar
No problems at all. Im running a restricter plate instead of a thermostat, after havin a stat stick closed on me. Car runs at about 180 max. The scoupe is mounted inside the nose and just presses up against the IC and rad. Trimmed the bumper support to fit it.
Old 10-31-2008, 09:48 PM
  #80
online170's Avatar
Car: 1987 Firebird
So trying to picture this.... if i stuck my head under the front of the car, i would see sorta "two air-dams"?
1 for rad, and 1 for IC?
Old 10-31-2008, 10:59 PM
  #81
67nova's Avatar
Car: 67 NOVA
Engine: SBC
Transmission: AUTOMATIC
Axle/Gears: 3:70
Hey, your twin turbo setup is the bomb...Where can I get a set of those turbo headers?
Old 11-01-2008, 04:03 AM
  #82
TA88GTA's Avatar
Well yes and no, the scoupe is one piece but has a diverter or air dam fro each cooler. Ill take a picture its easier for you to see than for me to explain.
67NOVA- sorry but you wont be able to find these headers anywhere but on my car, they were custom built.
Old 11-04-2008, 05:59 PM
  #83
1fas92's Avatar
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
Hello,
Do you have any closer pics of the headers. I was trying to get a closer look!
Thanks,
Robbie
Old 11-26-2008, 02:07 AM
  #84
allenfre's Avatar
Hey guys, havent been on the site in a while but i thought you might injoy a few progress photos of my 88 notchback GTA. Project has been stalled now for the past 2 1/2 years but im back on her and shes alteast running now.
This is the cleanest set up I ever saw here since last week. I wonder how far can this one go knowing this has been stalled now for past 2 1/2 years
Old 11-26-2008, 11:47 AM
  #85
TA88GTA's Avatar
Thank you.
and for the guys waiting for photos of the air diverter, you'll have to wait a little longer. I was making a few 180+mph pulls and the tack welds on the aluminum came unglued. guess the aluminum was a little to thin and tore around most of the welds. Lucky it didn't damage anything else. But ill have pics of the new one soon as its done.
Old 11-26-2008, 01:16 PM
  #86
11sec92z's Avatar
Car: 1992 Z28 "clone"
Axle/Gears: Moser 12 bolt w/ 4.11s
That is the sickest twin turbo set-up in a 3rd gen I have ever seen !!!
Old 11-26-2008, 05:57 PM
  #87
allenfre's Avatar
Thank you.
We'll be happy to see that thing evolve to a something awsesome. Thanks for keeping us posted
Old 12-02-2008, 11:53 AM
  #88
Former Sponsor
BMR Sales's Avatar
Nice job, looks good!
Old 02-04-2009, 12:30 AM
  #89
Any updates?
Old 02-05-2009, 01:36 AM
  #90
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
subscribed
Old 02-05-2009, 07:08 PM
  #91
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
Hey man, well done. I didnt mean to doubt you earlier but you put all the real doubters to rest. Awesome job, you obviously know what your are doing and what you wanted.
I only hope my single setup will measure up in some way. Again, Nice job!
Old 02-06-2009, 08:49 AM
  #92
Former Sponsor
BMR Sales's Avatar
Damn car sounds good!
Old 02-21-2009, 09:41 PM
  #93
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Havent read this thread in a while. Great build, I am hoping my setup turns out somewhat as nice as yours You've done very well with this build, I am impressed.
Turbo engines are all low compression #s. The pressure of 20+ lb of boost is where the HP comes from. Start with 11 to 1 & 2-+ lbs of boost, & say goodbye to your heads. Doubtful it would even start.
what i meant was he made over 500 hp naturally aspirated before the turbos were on. Thats with 8 to 1 compression. I find that amazing because my 383 was over 11 to 1 built for power with a fair sized cam and i made around same 500hp. 8 to 1 should give up 15% in power or so. Or more. Thats an incredible n/a 383 to make that power at 8 to 1
Old 03-07-2009, 06:09 PM
  #94
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I would also like to see a few pics of the headers.
Old 03-13-2009, 08:48 PM
  #95
Duratys's Avatar
Car: 91GTA 89TTA
Engine: 305 3.8 Turbo
Transmission: MK6 2004r
Axle/Gears: G80 3.42s 3.27s
Nice clean car to start off with....Impressive work!
Old 04-16-2009, 06:47 PM
  #96
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
that thins is BAD ***!!! Seeing clean TT 3rd gens AND 6spd make me wish i was loaded on money and could afford to build one. What kinda blow off valve do you have? or do you not have one?? Sounds bad ***
Old 04-16-2009, 08:12 PM
  #97
lt1z350's Avatar
get it down the track yet? just curious what it would run at that power level. I am not running close to that much boost and close to those numbers with a single turbo setup and 383. What is the rest of the motor? heads cam compression so on. My car seems to be a freak of nature for how fast it is on 6 lbs I have played with 10 lbs on the street not the track yet and am going above and beyond my 42 lbs injectors and cant get the afr right so have to keep it at 6 lbs. even at a 13 to 1 lean on 10 lbs feels like 100 more hp though. cant wait to start playing with 12 to 15 lbs on it but need more fuel first. What injectors your running and rest of fuel system. I am sure I will hit similar power levels and looking to see what i might need . I might be making more than I think as the car is heavy and fast. Right now dont want to put it on the dyno afraid to blow up hte rear as on the street or track it spins alot and think that is saving the rear end. on the dyno and not spinning might kill it. If you can go down all your combo that would be great. thanks.
Old 04-16-2009, 08:43 PM
  #98
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i didnt think 42lb injectors could do over 500whp? most guys run 60's for 600-700whp. My buddy maxed out (100% cycle duty) 60's at lsx pressure (makes them like 72lbs) at 708whp.
Old 04-16-2009, 09:10 PM
  #99
Originally Posted by lt1z350
10.5 @ 138 on 6 lbs yikes....
Am I reading this right....?
Old 04-16-2009, 11:45 PM
  #100
1fas92's Avatar
Car: 1992 Z28
Engine: Forged LS3
Hello,
I would love to see that car in person! I will be in Vancouver, WA in July this year! I know you live in Vancouver, B,C, Canada would it be possible to see your car?
I live in Carrollton, TX which is a suburb of Dallas, TX. I will be a long way from home! And would love to take a look!
I guess let me know!
I am in the process of building my twin turbo 92 Z28.......
Thanks,
Robbie
1fas92
Quick Reply: Twin turbo progress pics
